Instead of plug/mold for roof?
Discussion in 'Fiberglass and Composite Boat Building' started by member78916, Nov 9, 2023.
  1. kapnD
    Likes: 381, Points: 83, Legacy Rep: 40
    kapnD Senior Member
    I’m thinking the OP was suggesting using aluminum foil as a bond breaker between the foam mold and layup.
    BlueBell likes this.
  2. waikikin
    Likes: 177, Points: 73, Legacy Rep: 871
    waikikin Senior Member
    Most success is had with pre finished sheets/melamine etc, back before that available we used to use masonite, shellac and johnsons floor wax, corner fillets can be done with poly filler plus wax and pva.
    Jeff.
    fallguy likes this.
  3. Geno67
    Likes: 30, Points: 18
    Geno67 Clueless Member
    Wow. What kind of foam is that? He called it PVC. That is amazing 90 kilos to break a piece that weighs 360 grams and spans half a meter with one layer of glass on either side. I bet you could build a hardtop I could walk on with a couple of layers on each side.
  4. wet feet
    Likes: 364, Points: 83, Legacy Rep: 124
    wet feet Senior Member
    He called it PVC because that is what it is,the best type of foam for general marine use but not the cheapest foam available.There are many different brands and here are a couple of examples; Structural Core Materials https://www.gurit.com/structural-core-materials/
    Divinycell - PVC foam core materials from Diab https://www.diabgroup.com/products-services/divinycell-pvc/.
    The earlier suggestion to use sheets of melamine faced material to build a mould is the way I would approach the job as it greatly reduces the time needed to get a good finish.I'd expect the corners to need a little attention though.
    bajansailor and Geno67 like this.
  5. kitcarman
    Likes: 1, Points: 3
    kitcarman New Member
    That dodger - and the videos are first - class. What a great result. Got me wondering whether honeycomb (nidaplast or similar) would get a better or worse strength or be lighter? Possibly not much in it, but does anyone have experience of PVC vs honeycomb?
  1. Runhammar
  2. eam
  3. ber1023
  4. cando2
  5. mrdebian
  7. Gasdok
  8. itchyglass
  9. mrdebian
  10. weldandglass
