Instead of plug/mold for roof?
Discussion in 'Fiberglass and Composite Boat Building' started by member78916, Nov 9, 2023.
  1. member78916
    member78916 New Member
    Greetings to all,
    Instead of using a mold/plug to create a hard-top roof for my boat, why can't I just use foam material and design the roof the way I want, cover it with aluminum foil and then plaster on top of it all?
    Possible or not?
    Downsides doing this method?
  2. kapnD
    Likes: 545, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Are you talking about cement plaster as used on exterior walls of buildings?
    It is often applied over styrofoam, but that foam is always securely fastened to a solid substrate, where your hardtop is usually fastened to a skeleton of tubing. How will it be fastened?
    What is the function of coating it with aluminum foil?
    BlueBell likes this.
  3. Tops
    Likes: 123, Points: 43
    Tops Senior Member
    Dodger build for a sailboat, foam and fiberglass.
    Geno67 likes this.
  4. wet feet
    Likes: 617, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    Is there some reason why you can't use simple foam sandwich?Just hold the foam to shape,glass the easiest side,flip it and glass the other side.
  5. member78916
    Will use XPS foam in sandwitch and then sand and cut to get the design I want.
  6. member78916
    Will use XPS foam in sandwich and design it with curves and indents. Aluminium foil will be used as barrier in case the foam cant handle the polyester resin. Have not thought of what to use as release agent though.
    When the roof is done and fiberglassed and dried I will then turn it upside down and do some more plaster on the inside to prepare it for aluminium tubing and reinforce areas.
  7. member78916
    Thanks! Never heard word dodger before in boating terms =) Nice video! But what a pain to do it with those thin foam sheets.
  8. BlueBell
    Likes: 1,238, Points: 113
    Really? Where on EARTH have you been?!
  9. wet feet
    Somewhere where using XPS for a boat is a good idea? A good quality thin foam sandwich build would be ideal.
  10. kapnD
    kapnD Senior Member
    The bond between the skin and core is hugely important for the integrity of the end product, so using anything that breaks that bond is is a mistake. Find foam and resin that are compatible!
  11. fallguy
    Likes: 1,969, Points: 123, Legacy Rep: 10
    The easiest way to build the hardtop is to make a frame of the shape and strip plank with marine foam or use scrim or fasten it to formers.
    XPS is not suitable for a hardtop. The shear rating is too low and so is compressability. Marine foams are much better, but a hardtop usually also gets coosa or plywood inserts where hardware attaches.
  12. Tops
    Tops Senior Member
    If I understand correctly, OP is thinking of using XPS+foil+PE resin for a tool/plug/mold instead of a core.
    One would need to do a whole tooling prep 'wax on/wax off 'procedure before molding to get the part's PE gelcoat or resin to release cleanly from the tooling's PE resin. Lots of coats of Partall #2 wax and maybe some PVA...the pro's can explain this better than I can.
  13. wet feet
    All true. You missed out what happens when polyester resin meets polystyrene though.
    fallguy likes this.
  14. kapnD
    kapnD Senior Member
    I found this post to be confusing, did I miss something, perhaps on an entirely different thread?
    “Instead of using a mold”, and “plaster” indicates something entirely different.
    Aluminum foil? You must be joking!
  15. BlueBell
    I like the aluminum foil.
    Imagine the radar reflection the search helicopter would get back from it.
    Multi layer of course.
    Geno67 likes this.
    1. Runhammar
    2. eam
    3. ber1023
    4. cando2
    5. mrdebian
    7. Gasdok
    8. itchyglass
    9. mrdebian
    10. weldandglass
