Instant BM
Discussion in 'Stability' started by terhohalme, Jan 29, 2010.
  1. terhohalme
    Likes: 38, Points: 28, Legacy Rep: 506
    terhohalme BEng Boat Technology
    Hello,
    Found one day a very simple equation for metacentric radius in modern sail boat:
    BM = 0.1 B^2 / T, where B is the waterline width and T is the draught of canoe body.
    This formula looks to be right in a few percent.
    How did I get there?
    Displacement volume D = L * B * T * Cb
    Second moment of the water plane I = L * B^3 / 12 * k
    k is a constant and depens on waterplane shape, approximation k = Cw^2
    Just using algebra:
    Metacentric radius BM = I / D = B^2 / (12 T) * Cw^2 / Cb
    (found later, this was statet by Mc Cloghrie)
    Approximation: In modern sailboat hull Cw is about 0.7 and Cb about 0.4, so Cw^2 / Cb is about 1.2 . Put this in BM equation, we have after reduce:
    BM = 0.1 B^2 / T
    Example a boat with B = 3.0 m and T = 0.6 m have BM = 0.1 * 3.0^2 / 0.6 = 1.5 m
    This very simplistic, but tells quite clear what geometric factors influence on instant stability.
    Any comments? Seen this before?
  2. TeddyDiver
    Likes: 124, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    But.. but.. then just anybody can calculate BM
    :p
  3. terhohalme
    Well, anybody can calculate his/her money balance:
    Property = Earnigs - Expencies
    Still, only some are rich.
  4. Guillermo
    Likes: 188, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    I got another approximation as:
    (See: http://www.boatdesign.net/forums/stability/what-bm-t-b-2-a-20642.html)
    (BM*T)/B^2 = 0.08*Cwp^2/Cp
    Asuming Cwp = Cp ^ 2/3 (Schneekluth)
    we come to (BM*T)/B^2 = 0.08*Cp^1/3
    and so BM = 0.08*Cp^1/3*(B^2/T)
    For an efficient motoring hull Cp = 0,63
    so roughly BM = 0.07 B^2/T
    Another approximate formula is:
    BM = (0.008 +0.0745 * Cwl^2) * B^2/(Cb*T),
    As we can estimate also the vertical centre of buoyancy using:
    Munro-Smith: KB = T*Cwl/(Cb+Cwl), or
    Normand-Morrish: KB = T*[5/6 - Cb/(3*Cw)]
    (The M-S formula usually gives a value about 0.01*T lower than the N-M)
    we can, as KM = KB + BM, get KM and then performing a weights/centers calculation estimate KG and so GM.
    Note: L = length, B = beam, T = draft, Cb = block coefficient, Cwl = waterplane area coefficient
    Cheers.
  5. terhohalme
    This is true only if Cm = 1 then Cp = Cb*Cm = Cb
  6. Taildragger
    Taildragger New Member
    Hello,
    Would anyone know Terho Halme's email contact details as the email quoted on his website keeps rebounding?
    Cheers
  7. terhohalme
    My website is outdated history... just foating somewhere in cyperspace and no controllable anymore
    Just pick my name and send me an email.
    Terho
  8. Taildragger
    Hi Terho,
    Tried to email you without success.
    Could you email me on: janie.50@bigpond.com
    I would just like to canvass your opinion on designs.
    Cheers
    Chris
