installing transducers on aluminum hulls
Discussion in 'Boat Design' started by AkiraLe, Mar 10, 2018.
  1. AkiraLe
    AkiraLe New Member
    New boat and I need to install a transducer on aluminum hull, I was told about 5200 and then read it was for fiberglass and wood hulls. Any one with insight that can help would be much appreciated.
  2. Barry
    Likes: 465, Points: 83, Legacy Rep: 158
    Barry Senior Member
    Need a little more information
    What type of thru hull is it? Model material is it adjustable, ie for either height or adjustment from normal?
    Is this a thru hull and you are going to use 5200 to seal the opening?
  3. jorgepease
    jorgepease Senior Member
    sikaflex products might be of help, many of them bond to aluminum
