Thanks... This is some useful info.
I would use Nylon cloth instead of dynel or xynol, it's going to be a lot cheaper I think and Nylon cloth is also abrasion resistant.
I am talking tarp like thickness.
Glass the outer hull put on those keels and cloth over keels.
And you could use nylon instead of glass for the bottom, you know glass can crack, nylon never will. It is alround more durable.
Likely boats with glass fibers are stiffer than nylon,
BUT nylon on wood is going to be great.
Nylon vs Polyester - Difference and Comparison | Diffen
I dont know why nylon is not used more on boat hulls.
What glue works best on nylon? - Glue Things
Epoxy Glue:
Prepare to be amazed by epoxy glue. This adhesive is like a ninja warrior when it comes to bonding nylon. It’s tough, water-resistant, heat-proof, and chemical-proof – basically indestructible. But beware, working with epoxy can be a bit tricky since it requires careful mixing and patience while it dries.
Exploring the Properties of Nylon:
Nylon is a type of polyamide that boasts incredible mechanical properties. It is created through polymerization, where monomers are linked together to form long chains. This process results in a material that is not only robust but also resistant to wear and tear.
Strength and Durability:
One of the key characteristics of nylon is its high tensile strength, allowing it to withstand significant force before breaking or deforming. This property makes it ideal for applications such as ropes, cables, and fabrics used in outdoor gear and sports equipment.
Resistance to Environmental Factors:
Nylon exhibits excellent resistance to abrasion, chemicals, and heat. It can maintain its integrity even in harsh environments, making it suitable for automotive parts, electrical insulators, and industrial components.
Low Coefficient of Friction:
Nylon’s smooth texture and low coefficient of friction make it perfect for reducing friction and wear in moving parts such as bearings and gears. This property ensures smooth operation and longevity.
Versatility in Processing and Modification:
Nylon’s versatility extends beyond its mechanical properties. It can be easily molded into different shapes using techniques like injection molding or extrusion. Furthermore, nylon can be blended with other materials to enhance specific properties or characteristics.
Types of Nylon:
Nylon is available in various grades and forms to suit different applications. Nylon 6/6 (PA66) offers a balance of strength, toughness, and chemical resistance. Other variations include nylon 6 (PA6) and nylon 12 (PA12), each with unique properties.
Types of Glue for Bonding Nylon
Selecting the right glue for bonding nylon is crucial to ensure a strong and long-lasting bond. Whether you’re working on a craft project or repairing a broken nylon strap, the perfect adhesive is essential. In this article, we will explore the various types of glue suitable for bonding nylon, discussing their unique advantages and considerations.
Epoxy Glue – Unmatched Strength and Durability:
Epoxy glue is a popular choice for bonding nylon due to its exceptional strength and durability. Formulated with a resin and hardener, it creates a powerful adhesive when mixed together. This type of glue is perfect for applications that require the bond to withstand heavy loads or stress. However, it’s important to note that epoxy glue can be messy to work with and requires careful mixing and application.
