Inquiry for information from experienced boatbuilders and boat designers
Discussion in 'Multihulls' started by IvanAntun, Feb 8, 2024.
  1. Rumars
    Likes: 1,316, Points: 113, Legacy Rep: 39
    Rumars Senior Member
    Ivan, it's really simple. The crossbeam must reach from the outside of the ama, across the main hull to the outside of the other ama. You fix it down at every gunwhale on each hull, so six attachment points per beam.
    Now if for some reason the crossbeam can't be one single piece (for example you can't find the appropriate lenght for sale, or it is to heavy to maneuver alone) you can make the crossbeam from two pieces. This two pieces can be spliced into one and fixed to the hull like a one piece beam, or you keep it in two pieces and fix it like in the Astus example because that's the simplest way of doing it.
    BlueBell likes this.
  2. IvanAntun
    Likes: 1, Points: 3
    IvanAntun Junior Member
    Hi Rumars,
    I've seen some examples of crossbeams which are only fixed at one point on the mainhull. But the 6-point fixation for each beam is would then be more suitable, of course. Thanks for the additional explanation
  3. IvanAntun
    Likes: 1, Points: 3
    Hi SolGato thanks for your response,
    this is a great example and if it were not for the two half-beams and if one beam would be intended for the amas then this system would be the best solution. It would avoid the splicing, too. The weight would still be possible for one person mounting/dismounting (although on the limit).
  4. IvanAntun
    Likes: 1, Points: 3
    On the tri you mention, are these inspection holes used to set the nuts in place, for the bolts, inside the ama hull? Or just for inspection
  5. IvanAntun
    Likes: 1, Points: 3
    Been reading your and SolGato's last responses for a lot of times recently.
    The 4-metre beam is just at the limit of what would be possible to maneuver alone, and since the dismounting would be intended as seasonal, ...
    It would really simplify the matter of attaching the amas to the mainhull.
    I would be interested to know whether a two-part beam spliced into one is inferior in strength (or rather, how much inferior) to a single-part crossbeam, if dimensions are the same. There is certainly an additional mass of the splicing tube.
    And if this difference is not negligible for the intended dimensions, in which aspect of stress does it manifest the greatest in pitch or torsional connecting moments or in transverse bending. Perhaps because of the lateral "cut" at the middle, the simple shear stress would be the largest difference between these two crossbeam types.
    Anyway, thanks
