Hi Rumars, thanks for your post, highly appreciated since it clarifies a lot
can you just specify what do you mean between the panels, is it the side panels of the ama you are reffering to (so the block of ply or solid wood would be installed horizontally and below the top panel/ama deck) ?
It is indeed a cantilever beam without waterstays
awesome info. In that regard, If I understood correctly, the middle plate should be omitted and bulkheads every 20-30cm should be installed, as well as the side plywood plates should be cut so the fibres are 45deg from the horizontal line of the beam, as well as to use solid wood for the top and bottom flanges as every other layer in the plywood would not align the fibres with the longitudinal plane of the beam as their angle would be offset by 90deg. XPS foam is clearly then not adding anything structurally.
From comments here and this post: Design of wood epoxy trimaran beams https://www.boatdesign.net/threads/design-of-wood-epoxy-trimaran-beams.68629/ by Adrian Baker, as well as Kurt Hughes' website and his insight into the matter, it seems to me that due to the complexity of building the crossbeams out of ply and GRP, the cost, and the larger dimensions required, all this points to aluminium round beams being perhaps a better choice. Also it seems to me a round groove is better due to glassing the right angles for the square beam.
I would appreciate any thoughts about the following:
I found 6082-grade aluminium round tube beams with a 150mm diameter and a 5mm thickness, they are 6.15kg /metre. From what I understand (from other posts, especially the abovementioned by AdrianBaker) this is perhaps more than sufficient since the tri in question is to be 22.6', with the total beam from ama to ama being 13'. 400-450kg hull dry weight, each ama 70-80kg, 950-1100kg displ.
Since each aka would be 2 metres, that would be about 4x2x the difference in mass between perhaps a sufficiently dimensioned alu beam (i.e. 140mm dia. / 4mm thickness), which would be about 13kg difference. I would prefer to have the akas stronger than neccessary
Understood; so basically from what I can see, a good slot for the beam, then two or more connectors as well as polyester webbing with ratchets (as can be seen from SolGato's picture above?) would be a good combination. The attachment to the ama's side below the beam to which the webbing would be lashed, would it need to be metal or is solid wood element sufficient?
Thanks
To answer your original questions:
1. Water protection is achieved by a ring of thickened epoxy between the aka material and the bolt. For compression reasons the bolt location must be solid material, so you have two options:
a.) install a block of (ply)wood between the panels, drill oversize, fill with thickened epoxy, drill final hole, or
b.) install a bushing (fiberglass pipe or drilled fiberglass block)
2. The aka is loaded in bending, it's a cantilever beam (I presume you don't have waterstays).
A hollow rectangular beam will have the top and bottom flanges carry the load, the sideplates keep them at the proper orientation and resist torsion.
Your proposed arrangement is possible but needlessly heavy and complicated. The middle plate is not necessary, it doesn't carry any significant loads (neutral axis of I beam). Making the top and bottom flanges out of plywood means that half the wood is going into the wrong direction and is just dead weight. An efficient beam would have the top and bottom flanges made from solid wood, and the side plates made from plywood, ideally cut diagonally from the sheet.
XPS foam is useless from a structural point of view, so the beam would probably need some additional bulkheads installed. Filling the remaining voids with foam is a personal choice between added weight and no airspace.
It doesn't matter how exactly you attach the ama to the aka. The goal is always to make a secure connection that doesn't move. For that the first thing is that the aka doesn't collapse under the load (solid blocking and washers). Second is that there is no rotation, so you need at least two spaced connectors, and third is that there is no movement in the connection under load. Lashing works, but it's complicated and high maintenance, that's why more modern wharrams transitioned to prestreched polyester webbing and ratchets. Bolts need and additional tool (the wrench) and a form of security against vibration (additional nut, locknuts, castellated nut, etc.). For stainless bolts go with bronze nuts, that prevents galling. If you can keep track of a wrench and some spare nuts, bolting is preferable.
Thanks
