Injectable foam/core
Discussion in 'Materials' started by erikssonniklas, Oct 2, 2007.
  1. erikssonniklas
    erikssonniklas Junior Member
    Hi Everyone
    I am looking for injectable PU or PVC (or any other you can recommend) foam which I hope to inject into a 3m long mould. Some key properties I am looking for is:
    - Density – somewhere between 35-60 kg/m3
    - Short cure time – in the mould
    - As low internal mould pressure as possible – I’m hoping to be able to use composite moulds
    - Low shrinkage when cured
    - Temp/fire/sound properties not prior
    This method if possible will save me a lot of time, when I don’t have to mill each divinycell block by hand.
    Thankful for any comment.
    /Niklas
  2. kach22i
    Likes: 111, Points: 63, Legacy Rep: 1222
    kach22i Architect
    Are you asking about something like Z-Plex?
    http://www.3tex.com/
    They are making a large hovercraft out of it.
  3. erikssonniklas
    Thanks kach22i, but no.
    I'm hoping to pre-cast the foam core before i laminate around it.
    //Niklas
  4. Ike
    Likes: 369, Points: 83, Legacy Rep: 1669
    Ike Senior Member
  5. Pericles
    Likes: 135, Points: 63, Legacy Rep: 1307
    Location: Heights of High Wycombe, not far from River Thames
    Pericles Senior Member
    kach22i
    Thanks for the link to Z-Plex. Very interesting.
    Pericles
