weldandglass
Junior Member
- Joined
- May 10, 2010
- Messages
- 32
- Reaction score
- Location
- Gulf Coast of Texas
I've been wet bagging all of my parts to date but I'm about to make an order of infusion materials so I can make the switch.
I'm infusing a 18' by 5' hull and cap mold for a little skiff. I've got a hull that's near completion that was wet-bagged. I'm going to experiment with infusion on the remaining bulkheads and sole of the partially complete boat to get a feel for infusion, then start another hull and cap and do them fully with infusion. All parts are biaxial e-glass skins with H-80 divinycell core. When I'm wet-bagging, I'm using Proset LAM239 epoxy with the extra slow cure speed hardener. I'm in Texas so during the warm months I need all the extra working time to get the parts wet-out prior to pulling vacuum. I'm going to switch to the Proset INF114 resin for infusion. My gut tells me to keep working with the extra slow hardener so that I can have the luxury of maximum working time. Other than a slower cure cycle and having to wait additional time prior to demolding, are there any disadvantages to using an extra slow hardener for infusion?
Also, all the core panels in the mold are developable. With all the wet-bagging I've done, I just used plain H-80 and perforated the core myself. Switching to infusion, I'll need to order perforated H-80 but I have two areas of core towards the bow that will require perforated and scored core because there's a little bit of curvature. If I use perforated only in most of the layup and have two core panels that are scored and perforated, will this result in two different infusion rates? I want to minimize use of the scored H-80 in order to reduce resin uptake by the core and minimize weight, if possible, but if this creates issues for an even infusion I may need to look at other strategies.
Any advice would be much appreciated.
