I am trying to figure out my infusion plan for 4' x 8' sandwich panels of CarbonCore polypropylene honeycomb. I was going to have two layers of 1808 on both sides of the core. The honeycomb has a polyester veil that is thermoformed onto the cells acting as a scrim. I was under the impression that the plastic coating under the scrim created an air tight seal between the scrim and the inside of the cells. However I heard from someone yesterday that they believed the scrim coat was slightly porous and would allow resin to flow into the cells when it was vacuum infused. So that is my first question...
Has anyone had experience with this material and successfully infused it without resin migrating into the cells?
If the honeycomb is not porous, or only VERY slightly porous, then that fact alone makes it more difficult for the resin to travel along both sides of the core during the infusion. Usually a perforated or grooved core is used to allow resign to flow on both sides of the core. To eliminate that issue I was going to layup my mold as follows...
Waxed aluminum mold
flow media
peel ply
1808
1808
core
1808
1808
peel ply
flow media
bag
I was going to have the resin supply line on one 8' long side of the panel. The resin supply section of the mold will have the full sized sheet of flow media down first, then a small strip of flow media under the 8' long spiral tubing then another strip of flow media above the tubing and then the full sized sheet of flow media on top of that. This should hopefully allow an even flow front across the entire panel for the 50+ inches of resin travel.
I was then going to stop the full sized sheets of flow media 6" before the end of the panel so the resin flow can slow down before it gets to the vacuum source spiral tubing.
The vacuum spiral tubing was going to have at least three evenly spaced suction tubes with clamps so I can close those tubes off if the resin front gets to those sections 1st.
I know 50+ inches of travel is a long way for resin to flow, but I was hoping with the flow media it wouldn't be an issue. Thoughts? Recommendations?
Once I have this section figured out I will share more details about this infusion.
Thanks,
Zac
Waxed aluminum mold
flow media
peel ply
1808
1808
core
1808
1808
peel ply
flow media
bag
Thanks,
Zac
