Inboard Engine on Inflatable
Discussion in 'Boat Design' started by mistyreiny, Sep 10, 2025.
  1. pistnbroke
    Likes: 40, Points: 48, Legacy Rep: 404
    pistnbroke I try
    Go buy a Hangkai 6HP 2 stroke outboard and at least a 10 ft boat
  2. montero
    Likes: 88, Points: 28
    montero Senior Member
    “Why are you afraid, O you of little faith?”
    I know at least two way of folding infladable hull build. First well known is Zodiac way , where transom is glued between the tubes. Second is a solution where transom is connected to the folding bottom and transom is sealed by soft transom skin from the outside. There was some German designs also my first hand made inflatable was build that way. It's possible to put diesel inboard into folding inflatable but why ?
  3. kapnD
    Likes: 602, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Just looked this up, doesn’t show good dimensions, but at 7’7” loa, it’s lucky to be 4’ wide, and over 2’ of that will be the tubes.
    The motor is hot and noisy, and will be about your knees and feet no matter where you sit, probably on the tubes, as the motor will be where the only seat was. The exhaust will be conveniently located near your face.
    The best aspect of your plan is that it will be a relatively low cost learning experience.
  4. comfisherman
    Likes: 549, Points: 113, Legacy Rep: 10
    comfisherman Senior Member
    Bearing, shafting, any kind of packing, prop and even a budget coupler will make a small outboard look like a bargain.
    kapnD and montero like this.
  5. gonzo
    Likes: 2,415, Points: 123, Legacy Rep: 2031
    Religion aside, technical solutions are realistic designs.
    bajansailor likes this.
