Bukmaster9
Junior Member
- Joined
- Jan 20, 2021
- Posts
- 19
- Reaction score
- Location
- New Orleans, Louisiana
I am in need of fiberglass boat design help. Please let me know if interested.
Note: This feature may not be available in some browsers.
@TANSL I cannot find how to send a PM... my apologies.. I just signed on to this forum. you can reach me by email bukmaster9@gmail.com or welcome to send me a PMWelcome to the forum, @Bukmaster9. I'm interested, at least to start talking. How can I help you? Send me, if you wish, a personal message for more details.
No I am not in the process yet. The pictures are of a project that was done a couple years ago by another guy. He used the exact 24' privateer hull I intend to use. The two acloves on the sides are for trim tabs and the one in the middle is a tunnel drive ( suppose to help the boat get on plane quicker in shallow water when the motor is trimmed up).So you are already in process of adding the three feet, going on the above picture ? What are those alcoves at the transom intended for ?
@bajansailor I don’t have the hull yet. I am trying to do as much as I can now so when I get the hull the project can take off runningBukmaster, the above photos are impressive - but could you post some showing the current condition of your boat please?
I presume that you will install new stringers in the same position as the old ones?
Re the extension, will you just follow the natural curves of the hull, or will it be a 3' parallel section added on?
I have seen quite a few boats here, of all shapes and sizes, some fibreglass, some wood, where they have added extensions on the back.
Your length to beam ratio will increase, but not by a lot. You probably will not need extra power for the stretched version, compared to the 24' length.
As Mr E says, try to locate your heavy items, and especially the consumables like fuel, at or near the longitudinal centre of buoyancy of the boat.
What type of power are you planning on installing on your boat?
Re that abrupt change of section in the tunnel, I would have thought that this would just generate a lot of turbulence?
I cannot see why it is needed, especially so if you have an outboard engine on a bracket standing off the transom.
Are you planning on building a similar tunnel, along with similar alcoves for the trim tabs?
