Impulse 4.0 sailing dinghy plans???
Discussion in 'Boat Design' started by Caldera, Jul 22, 2011.
  1. Caldera
    Likes: 0, Points: 0, Legacy Rep: 3
    Caldera Junior Member
    Anybody know of a source for a good quality set of Impulse plans for marine ply? I searched google and did not find much.
    Thanks
  2. Caldera
    There sure does not seem to be a lot of options in the 13-15 foot sport sailing dingys as far as plans. I love th i550, but its to big for what I need.
  3. Richard Woods
    Likes: 175, Points: 63, Legacy Rep: 1244
    Richard Woods Woods Designs
    There are a number of similar singlehanded dinghies available. Especially in the UK. Try the Phantom (only if you are heavy), even the OK, Solo, Streaker would have similar performance to the Impulse.
    Or maybe my 14ft Stealth (http://sailingcatamarans.com/stealth.htm) might suit you
    Then there is Keith Callaghan's Hadron and no doubt many more
    Try the Royal Yachting Association (in the UK) or Yachts and Yachting, the UK's leading dinghy sailing magazine for more leads
    www.sailingcatamarans.com
  4. joz
    Likes: 0, Points: 16, Legacy Rep: 10
    joz Senior Member
    Building an Impulse
    Australian Amateur Boatbuilder Article by Mark Dennis
    The Impulse was originally designed as DIY boat to be constructed by the average handyman. In essence not much has changed in its 30 odd years of existence. Today some of the materials have become more exotic, but a new Impulse is not beyond the skills of the average sailor and handyman.
    A basic Impulse can be built from from 4mm marine ply with a small amount of solid timber utilising the stitch and glue method. Five sheets of 2400x1200mm plywood are sufficient for the task. If you desire to be a little more advanced an Impulse can have closed cell foam laminated to its ply floor, or if you are experienced it is quite possible and legal to home build an Impulse completely out of closed cell foam sheathed in fiberglass. A well built Impulse will be equally competitive no matter what the construction material used; it is really the builder's skill and experience level that dictates the chosen construction method.
    The Australian Impulse Association will provide all necessary documentation to build a plywood boat using the stitch and glue method. This includes full size paper templates, complete building and rigging instructions, as well as a sail number for your "new flyer" and a measuring service when it is finished. Build your own boat, it is a very satisfying way to go sailing! There are quite a few experienced Impulse builders in your state who are more than happy to assist you throughout your building project if you need any guidance. There are various commercial builders which include Tim Wilson and Jim Scott in Victoria
    Contact the Australian Impulse Association Registrar, Mike Howell, mandelhowell@optusnet.com.au This e-mail address is being protected from spambots. You need JavaScript enabled to view it to begin your new boat building project. You can also download the Class Rules here (3.4Mb File). You should also check out the profile on the D2 sail.
  5. Caldera
    I really like the Phantom.. It looks like a fun boat and it's a perfect design for use in the states where the population is getting larger and heavier. Its sad to say, but unfortunately a lot of kids (and adults) who are interested in sailing here are too heavy for the Bic or even the Laser class boats. :(
  6. messabout
    Likes: 482, Points: 83, Legacy Rep: 1279
    messabout Senior Member
    You might take a look at Paper Tiger from Dudley Dix drawing board.
  1. Pawel Gendek
  2. M4R1N
  3. Squidly-Diddly
  4. Squidly-Diddly
  5. jakeeeef
  6. rwatson
  7. Windmaster
  8. BMP
  9. Ryan Bailey
  10. Robert Biegler
