Importing Hull Lines From Autocad To Maxsurf
melisa.08
New Member
Joined
Jul 13, 2024
Messages
4
Reaction score
Location
Istanbul
I don't know why this happens. I got the offset table from my school project. I put them together as seen in the picture. But when i try to open that in maxsurf (dxf) it breaks into two piece and some lines became straight. WHAT CAN I DO?? I can't seem to find solution. Any advice?
Use the Autocad "DXFOUT" command to create the dxf file. In MaxSurf use "Import>>DXF Curves". (See attached figure)
Maxsurf doesn't need more than half the hull and it doesn't need the main deck either. Therefore, even if you only use half frames, you will be able to create a perfect model of the ship.
It still doesn't work :( i don't know what is wrong with my autocad dxf file. Thank you for your help I appreciate it :)
  • HALFHULL.dxf
    HALFHULL.dxf
Neither AutoCAD nor Maxsurf pose any problems for me. I am attaching the .msd file so you can work on it.
I am so sorry for late reply. I had exams :( I CAN'T THANK YOU ENOUGH!!!! This made me so happy i was feeling so anxious about it. Thank you for your time I appreciate it :)
