I'm to design a canal cruiser that can handle high seas...
Discussion in 'Boat Design' started by solitaire, Aug 17, 2012.
  1. solitaire
    solitaire Junior Member
    I'm to design a type of boat that is ruggied enough for canals yet having sea handling abilities that can easily accept 1m/ 2 - 3' waves on larger lakes or coastal areas. I figured multi-hull for ruggiedness and stability in terms of displacement variations. But I'm a bit confused about cats, trimarans, SWATHs and those Grainger DeltaForm designs.
    That's really the dilemma here: you should be able to walk around the boat and it having the capacity to take 1-6 people without leaning over in roll, yaw or altering its draght considerably. Yet on rough seas providing a reasonably smooth ride.
    Being designed primarily for canaling the maximum dimensions would be a draght of 1.5m, a beam/ width of 4.5m and stand 2.5m tall above the surface of the water.
    I figured a vessel at 6m long, 2.5m wide, or 8m long and 3.5m wide, with a draght of perhaps .5-1m. It's most likely to have a maximum speed of perhaps 10-15kt on open water.
    Feel free to through suggestions at me at your leisure! :)
    Edit: Oh, it's for motor propulsion.
  2. peter radclyffe
    Likes: 111, Points: 73, Legacy Rep: 680
    peter radclyffe Senior Member
    you are dangerous
  3. FMS
    FMS Senior Member
    Could you define if this is a boat you want to actually build or have built or if it's an academic project.
  4. solitaire
    You think so? Would you care to elaborate on that, please?
  5. solitaire
    But of course. This is a boat I want to build and wouldn't mind some experimenting, though perhaps not on the cutting edge academic level.
  6. DCockey
    DCockey Participant
    The size you propose is much small than the canal size limitations you give. What about the canal use will change the design?
    Do you know of any boats which are similar to what you are thinking of?
  7. PAR
    Solitaire, I think the real question is how much yacht design expertise do you have . . . as these questions suggest little, which suggests an ill advised adventure/project.
  8. Ad Hoc
    Likes: 1,971, Points: 113, Legacy Rep: 2488
    Sounds like the, "..I would like a really really fast boat, but at the same time, carry an artic lorry and a house.."
    Your principal dimensions suggest only one type of boat, a boat suitable for canals, yet the SOR of canal cruising is incompatible with your other objectives.
    Suggestions...ok...it's called compromise and understanding how your SOR affects design.
  9. Frosty
    Frosty Previous Member
    Why don't you design a sea going boat that can go on a canal. I dont think any one would notice the difference.
    An offshore class life boat would go on a canal.
  10. peter radclyffe
    you got it
  11. frank smith
    Likes: 14, Points: 28, Legacy Rep: 185
    frank smith Senior Member
  12. Pericles
    Likes: 141, Points: 63, Legacy Rep: 1307
    Location: Heights of High Wycombe, not far from River Thames
    Pericles Senior Member
    solitaire, an aide-mémoire for you, in your endeavours to reinvent the wheel.
    Draught: breeze or light wind.
    Draught: drink, usually drawn from a barrel.
    Draft: depth needed for boat to float.
    Draft: written document to pay money from one bank account to another.
    Draft: conscription.
    Draft: write a preliminary version of a picture, document, or plan.
    Draft: pulling heavy loads.
    How wide is your canal?
    http://en.wikipedia.org/wiki/Narrowboat
    Paul Fisher already has designs for canal use. Scroll down
    http://www.selway-fisher.com/Mcover30.htm
    Start with something compact.
    http://www.woodenboat.com/build-boat
  13. lewisboats
    lewisboats Obsessed Member
    Tongue planted firmly in cheek... I hope!
  14. lewisboats
    I don't believe there is a sailing requirement... motoring is what he said.
  15. lewisboats
    Sounds like a good place to start. I'm hazy on the canal conditions though... how deep?, is there current?, How much room required between opposing vessels?, Long term live aboard or Vacation housing?, normal occupancy?
