ideas needed for a large sliding roof hatch grp boat
Discussion in 'Boat Design' started by janner, Nov 23, 2013.
  1. janner
    janner New Member
    At Southampton boat show I looked at a very impressive high tec sliding roof hatch , but it came with a 2000 pound price tag , so only option is to self build GRP, could really do with some insparation, design ideas and advise on sliding mechanisms etc, The hatch size is 3ft x 4ft
  2. PAR
    You're talking about a huge hole in the top of a boat, which generally isn't a good idea. As to mechanisms, well keep it simple, as the fancy high tech stuff often works just fine, until it gets balled up with dirt, salt and other grime and jams open or closed, with no hope of freeing it short of a fire ax. Think about self lubricating parts and naturally "containing" assemblies.
  3. rwatson
    rwatson Senior Member
    Sanded fibreglass is pretty slippery, especially when wet.
    However, you can buy strips of Polyethylene ( the stuff that plastic cutting boards are made of ), that make heavy things slide easily.
    3ft x 4 ft isnt that big, and a properly designed glass hatch would have no trouble behaving itself on metal slides.
  4. janner
    janner New Member
    hi rwatson and PAR, Thankyou for your advice, any Idea where I can buy the right sort of sliders /mechanisms, I am in the proccess of trying to design and build a mould for the roof 10ft by 15ft, I need to lower an engine up to 250hp in through the roof hatch and through the engine room hatch,
  5. PAR
    Typically, there are a few approaches to this, the most common is a fully bonded in section, that's designed to be cut out, removed and bonded back in when a repower is performed. This is the water tight way to do it and structurally, much stiffer. Another way is exactly the same thing, except it's precut for you and typically bolted down, over bedding on a flange. This is simply a molded hatch cover, screwed or bolted down to a flanged opening and only removed during a repower. Lastly is a dedicated hatch, which can have hinges, struts, slides, parallelogram arms, etc. These are the weakest, most likely to leak, most likely to rattle, etc. They often are set into a drip rail/flange sort of thing to help shed water and stiffen things up. Which you employ is up to you, but generally this approach (hinged) isn't necessary, unless you're getting something else by doing it, such as more headroom or easy access to the engine for maintenance.
    Usually, when you have to pull and engine through a salon or pilothouse, after snatching it up through the sole, deck or engine room hatch, it's a two stage process, unless you have an articulated arm/hoist. An example is one I did this summer, where I used a standard boom style engine hoist on the deck, hoisted the engine up, then rolled the hoist, with the engine dangling, through the pilothouse hatch, out onto the cockpit sole. From there I used a gantry to hoist the engine out of the cockpit. I placed some 3/4" plywood down on the pilothouse and cockpit soles, to protect things as I rolled the hoist around and to help spread loads, without damage.
    What boat do you wan to do this to (year, make and model)?
  6. janner
    janner New Member
    hi PAR
    I have built the boat myself over the past three and a half years , I was given an old hull mold, was told the mold was a sea-lion possibly 30 years or more old ,no top ,I build a new hull molding then have had to design the rest, built and assembled it like a jigsaw ,I have aimed for a classic design rather than power boat look, so far she looks good , I am on the last leg , just need to design the rest of the wheelhouse from the waist up and roof, the idea was engine access and a sun roof as an added bonus , however I'm not a designer and value all info offered.
  7. CDK
    CDK retired engineer
    Look at kitchen drawers for ideas. The cheap ones have a plastic strip screwed on each side, resting on wood or an aluminum profile. They do slide as long as they are empty and have a lot of play.
    The ones that move without effort have metal guides and a set of small wheels, so they don't slide but roll. For a large hatch I would use aluminum U-profiles, fixed to the wheelhouse with countersunk screws and a number of small stainless ball bearings on short stubs attached to the hatch.
  8. FAST FRED
    FAST FRED Senior Member
    Look in any old boat building book and copy a companion way slide.
    Sparkman and Stephens has on line files as a start..
    The best do not leak even when a wave crashes aboard , so should work fine on top of a boat.
