I would like to know what boat this is, think it is from the 1970's
Discussion in 'Powerboats' started by JWRutgers, Sep 30, 2025.
  1. JWRutgers
    JWRutgers Junior Member
  2. BlueBell
    Likes: 1,305, Points: 113
    Can you post more pictures?
    Include the HIN on the corner of the transom.
  3. JWRutgers
    Thank you for relying.
    No HIN number available. I will try to get more pictures.
    The owner says he thinks it is a Bonson Wahler.
    It has a full fiberglass hull, about 16 Feet long.
  4. BlueBell
    You're welcome.
    If there's no HI Number then it may be a home build.
    I doubt that going by its appearance.
    The HIN may present if you carefully remove overcoats that have been applied.
    From where did the previous owner acquire it?
  5. gonzo
    Likes: 2,387, Points: 123, Legacy Rep: 2031
    Depending on where the boat was built, it may not have a HIN
    BlueBell likes this.
  6. JWRutgers
    The Boat has been sitting there for over 40 years.
    I do not think it is a home build. In Aruba mostly all is imported.
    I'll try to get more pictures. The boat and trailer are in a deplorable state. Would be great to fix them up though.
  7. jehardiman
    Likes: 1,514, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    With the fake lapstrake and bow cockpit it is not a Boston Whaler or similiar (like a Glastron or Bayliner) as those two things are not generally seen together as common design elements. It looks most like a Penn Yan which makes me think NE US/Canada or UK-EU manufacture.
  8. JWRutgers
    Some more pictures I was able to make that might be helpful, there is even a cactus growing inside the boat.:)
  9. tpenfield
    Likes: 166, Points: 43, Legacy Rep: 10
    tpenfield Senior Member
    Might be related to this company ?
  10. tpenfield
    Might be this . . .
    Lyman Boat Works, Sandusky, OH
  11. Ike
    Likes: 524, Points: 113, Legacy Rep: 1669
    Ike Senior Member
  12. JWRutgers
    The hull is the same, must be this manufacturer. Not a center console but otherwise very similar. Would love to find more information so will keep looking on the internet.
    Thanks for alle the reactions and help, appreciated.
