I was wondering if anyone could tell me if this odd boat forsale near me is seaworthy
Discussion in 'Sailboats' started by Mickey1234, Jun 24, 2018.
  1. Mickey1234
    Mickey1234 Junior Member
    It WEST system , 33ft , has a Cylinder yanmar engine and is cutter rigged, ultimately I'd like to sail from onOntar to Newfoundland, the price is definitely right can this boat do it or will it flip over and sink as soon as I leave the dock ? Thanks Screenshot_20180624-161215.png Screenshot_20180624-161215.png Screenshot_20180624-161215.png IMG_20180623_180144.png Screenshot_20180624-161215.png
  2. upchurchmr
    upchurchmr Senior Member
    Are you able to find out the designer and model?
    If they are selling they should be able to tell you.
  3. Mickey1234
    It say it's a Jay Benford design custom build I found some similar boats but nothing exactly the same
  4. troy2000
    troy2000 Senior Member
    Looks like it might be Jay Benford's 30' cutter Arrt…
  5. Mickey1234
    I know it's cutter rigged
  6. JosephT
    Likes: 108, Points: 43, Legacy Rep: 218
    JosephT Senior Member
    Suggest contacting Benford to help in identifying the model. Then, as with any boat purchase, get a survey done by a professional surveyor in your area. It looks seaworthy from the pictures, but you will need a professional survey done to reveal any problems including workmanship, mechanical, electrical, engine, rigging, etc. etc.
    Never buy a boat without a survey. Only hire someone from the Society of Accredited Marine Surveyors.
    A List of Every Marine Surveyor in Ontario http://www.pcmarinesurveys.com/Every%20Marine%20Surveyor%20In%20Ontario.htm
    fallguy likes this.
  7. kvsgkvng
    Likes: 8, Points: 18, Legacy Rep: 49
    kvsgkvng Senior Member
    If this boat has
    • displacement-to-length ratio between 200~300,
    • sail-to-displacement ratio between 15~16,
    • ballast-to-displacement ratio between 40% ~ 50%
    then I would say it suits my understanding of "seaworthiness" and I would buy this boat based on physical condition, equipment, sails, rigging, price, etc.
    Based on my understanding it is "a lead sled," because most likely it would not have those parameters.
    JMHO
    Mickey1234 likes this.
  8. fallguy
    Likes: 1,985, Points: 123, Legacy Rep: 10
    This is really interesting.
    Would you expound a little?
    Thanks.
  9. BlueBell
    Likes: 1,285, Points: 113
    Have it surveyed or take it out for a spin.
    Or both.
    That'll tell you if it'll "flip over and sink as soon as I leave the dock".
    The owner should pay for half the survey and then get to keep it, if you don't buy the boat.
  10. kvsgkvng
    Disp./Length defines how "heavy" the vessel is and it affects motion comfort among other things.
    Sail Area/Disp. mostly would help to predict and understand light wind performance.
    Ballast/Disp. helps to keep the hull upright in rough seas and high winds.
    Just to consider that the total displacement must also accommodate useful payload such as crew, supplies, equipment, fuel, spare parts and repair materials, etc.
    Also if this vessel is made out of plywood (not steel/aluminium), as flat surfaces may indicate, beware of hull problems as it appears to be rather old boat.
    Another thing to consider among other things, if you are going "all the way blue water," coastal cruising, gunkholing or beaching.
    JMHO
  11. motorbike
    Likes: 10, Points: 18, Legacy Rep: 87
    motorbike Senior Member
    Dont do it!
