i need help
Discussion in 'Boat Design' started by mill4590, Oct 3, 2013.
  1. mill4590
    mill4590 New Member
    good morning
    I boat my first boat but I think I made a mistake they have taken out the inboard engine and blanked it off but I am starting to feel a outboard engine will not work on it
    I have attached a pic of the back of the boat
    thanks in advance
  2. alan white
    alan white Senior Member
    Methinks you might go back to the seller and complain.
  3. Mr Efficiency
    Likes: 644, Points: 113, Legacy Rep: 702
    Hell of a deep vee on that boat, looks about 25 degrees. With an outboard she might float a bit high.
  4. mill4590
    mill4590 New Member
    it has large fuel tank I can use to waeigh it down if I filled it
  5. IMP-ish
    Likes: 9, Points: 18, Legacy Rep: 150
    IMP-ish powerboater
    Use an outboard bracket. I like armstrong and stainless marine brackets.
  6. mill4590
    mill4590 New Member
    does the prop have to be below the bottom of the hull
  7. kerosene
    Likes: 70, Points: 48, Legacy Rep: 358
    kerosene Senior Member
    yes..
  8. Mr Efficiency
    The black cat should bring luck to the project, imo.
  9. IMP-ish
    IMP-ish powerboater
    Rule of thumb is put your anti-ventilation plate level with bottom of hull to start.
    Bracket moves outboard back and can be raised up slightly but not too much.
    What's the measure from your keel to the chine?
