Fastest with equal sail
Discussion in 'Sailboats' started by Slowmo, Aug 27, 2004.
  1. Slowmo
    Slowmo Junior Member
    Do you know of 2 (or more) boat types that have about the same standard sail area?
    Analyzing and learning. :rolleyes: It would be very interesting to look upon some different boats with aproximately the same sail area.
    which hull is fastest, most seaworthy and why?
    I don't know much, but I hope you do. ;)
  2. Dutch Peter
    Likes: 8, Points: 28, Legacy Rep: 66
    Dutch Peter Senior Member
    Better look on the web for that, there are too many to list here.
    That's been done, you just have to know where to find the reports!
    But, go on, ask!!
  3. Slowmo
    Please, take two examples. Well known types is probably most giving. That's something to start with.
    If we allways should read "everything" first, befor debating.... there wouldn't hardly be any debate at all, would it? ;)
  4. Dutch Peter
    Two examples for you:
    Catalina 30 MK III
    L = 9,15 m
    Lwl = 7,62 m
    B = 3,3 m
    Sail area =40,6 m^2
    Weight = 4,7 tonnes
    J-92
    L = 9,2 m
    Lwl = 7,93 m
    B = 3,05 m
    Sail area = 41,9 m^2
    Weight = 2,5 tonnes
    So, my educated guess is the J-92 is faster because:
    Length of waterline is longer
    Breadth is smaller
    Ship is lighter
  5. Slowmo
    Hmmm. Naturally. When comparing two modells, with more or less the same design simple mathmatics gives the answer.
    From start I had a txt line saying "dinghies" around 10-20m2. Why? I naturally mean to compare more simple designs. They can look very different.
    Comparing computer designs of the same consepts is not much point since it's hard even to recognise the differences for a non trained eye.
    If I remember right some of the OS-classes are boats that origin from dark cellars ages ago.... which makes them interesting.
  6. Dutch Peter
    Slowmo,
    That's the second time you get back on an answer in a way I don't like!
    What's the problem? You don't like the answer, then change the question!
    You seam to know so much about the subjects your asking about, come up with 2 designs on your own, and we'll debat about those!
    Dutch Peter
  7. Slowmo
    I actually can't say two classes with the same sail area straight off.... :( so I have to look for that.
    I'll be back. :cool:
  8. Dutch Peter
    Here two others:
    Hallberg Rassy 36:
    L = 11,31 m
    Lwl = 8,72 m
    B = 3,55 m
    Weight = 7,5 tonnes
    Sail A = 65 m^2
    Fisher 37:
    L = 11,33 m
    Lwl = 9,91 m
    b = 3,66 m
    Weight = 14,2 tonnes
    Sail A = 61,4 m^2
    Now you tell me?
  9. Tad
    Tad Boat Designer
    Hey Dutch,
    In looking at the first example, I agree the J will probably (undoubtedly) be better around a short triangle course on Sunday afternoon.
    But, what about over, say, a month of gales in the Southern Ocean. In those circumstances might not the heavier, beamier boat (not necessarily the Catalina) end up ahead?
    Best, Tad
  10. Slowmo
    Different... should be easy ;o)
    Let's focus on main + jib only.
    What does the designs tell you?
    29'er (sail 12,5m2)
    Spec: http://www.wet-windy.co.uk/2150_29er.html
    http://www.29er.com/4027,275,1-0.html
    international 420 (13m2)
    http://www.420sweden.se/Assets/Pictures/index.htm
    http://www.420sailing.org.uk/index....al&PHPSESSID=6da80b269d7ea32d93ba07543f210c30
    international 505 (14m2)
    http://www.irbs.com/directory/Dmoz/Sailing/Class_Sites/
    It was my intention to find a flat bottom (2 or 3 chines) plywood sharpie, but so far I didn't find any typical example with 12-14m2 sail.
    Sailingboats pages
    http://dir.yahoo.com/Recreation/Outdoors/Boating/Sailing/Types_of_Sailboats/
    http://directory.google.com/Top/Recreation/Boating/Sailing/Classes/
  11. Dutch Peter
    Tad,
    Your probably right, and not to mention the Catalina is more appropriate for that kind of sailing. but I understood the question as " in principal " waht boat is faster?
  12. Coen
    Likes: 1, Points: 0, Legacy Rep: 39
    Coen Junior Member
    It is quite probable that a yacht or dinghy with the biggest Sail area, the longest waterline, the lowest wait, the smallest beam and the lowest block coefficient and prismatic coefficient will be the fastest (when none of the boats plane that is!)
    But in transatlantic races as mentioned before, a little bit more comfort comes in handy because the crew will get tired because the seaworthyness is smaller.
    Peter; In the 'Zeilen' (a dutch magazine) this month is a fun to read article about yacht design. I do not know if you read it, but it is interesting.
  13. Slowmo
    Do you say it's possible, or that it is likely :?:
    So there is a "simple formula" to find out the truth about this?
    In wich order are they important?
    Here is a 2-chiner, with a small 3'rd flat part in back.
    http://devlinboat.com/dcnancyschina.htm
    http://devlinboat.com/homebuiltoskari.htm
    Do you se any bad design things about this boat for a stitch and glue design? Consider the hull.
  14. Coen
    Coen Junior Member
    Okay, I say it in an onther way:
    A sailing dinghy is powered by wind
    A sailing dinghy's underfinds drag from
    • Wind
    • Waves
    • Wet Surface
    • Weight (the higher the weight, the lower its acceleration and deceleration)
    So if you will lower the drag or make the sail area bigger, the yacht will eventually go faster.
  15. Ilan Voyager
    Likes: 238, Points: 63, Legacy Rep: 758
    Ilan Voyager Senior Member
    A part the odd discussion about the fastest etc
    A hard chine skiff running pretty well is the old Fireball. Designed for plywood. Planning like crazy. Look for plans in the internet. It's an international class with a lot of gadgets hardware on. Do not be fooled use the hull and put the rigging you need. It may fulfill your requirements.
    In you look for a really fast thing about 12 sq of sail, take a class A solo catamaran. 5.5m long, 2.21m, mast 9m, 12.8 sq m of mainsail, about 75 kg. No jib. Run 2 miles/day, make some musculation, stop smoking and you'll see how it accelerates in a 12 knots breeze.
    When you find that the class A is slow, go to next step. The 18 sq meter with at least 9/1 rachet block, big arms needed. Cat 5.5m width 2.8 to 3.2m about 90 kg. If you weight less than 85 kg take a water jacket. 90 to 100 kg of skipper's weight recommended if the wind is above 10 knots. Very fast for a solo cat, mortal upwind, points very well. The Tornado have difficulties for following. Accelerates like a big motorcycle and make feel the monohulls as small mopeds.
    After that the Class C. Very expensive. Very high tech. But worth: 30 knots, 3 times the speed of wing going upwind, beating anything sailing in regatta. The Australian 18 footers have not the shadow of a chance.
