I don't understand what the reviewer's requirements mean
Discussion in 'Boat Design' started by sun, May 15, 2024.
  1. sun
    Likes: 13, Points: 18
    sun Senior Member
    I submitted a paper to a journal. The main content of the paper is the research on the force of the hull, and the Length Overall, Breadth, Molded depth and Weight are given in the hull dimension part. The reviewer asks "The ship's principal dimensions must be given", I don't understand, what other data do I need to give?
  2. Ad Hoc
    Likes: 1,971, Points: 113, Legacy Rep: 2488
    It is hard to comment fully, without reading the paper.
    However, displacement, draft, speed, frame spacing (if applicable) for example.
    It really depends upon the thrust of your paper and what values you use and where they are obtained from, if within the paper, are these sources given?..
  3. sun
    sun Senior Member
    Thanks for your reply. I used the above data to calculate the floating state, stability, pier reaction, total longitudinal bending moment and torque of the hull
  4. Ad Hoc
    Are you able to post the paper so I can review and comment more fully?
    Or, if you don't want to post it publically, you can send it to me via email.
    baeckmo and fallguy like this.
  5. sun
    sun Senior Member
    What's your email address?
    1. Squidly-Diddly
    2. thenavalarch
    3. river runner
    4. Thule
    5. Damon7
    6. Sam I Am
    7. OneWayTraffic
    8. thenavalarch
    9. big_dreamin
    10. DocScience
