I don't endorse guessing when it comes to making a claim
however, my claim I think is backed up by
Regarding the Reynolds number - yes, it is a number which relates the speed, the characteristic length and the viscosity. A very important number in aerodynamics, serves (among other things) to:
1) assess in which turbulence / vorticity regime does a body operate at a certain air speed
2) assess how similar and comparable are two airflows around geometrically similar bodies
3) help correctly extrapolate data from scale models to full-size objects.
An airflow at Re=100.000 is radically different respect to an airflow at Re=3.000.000, even if the body is the same in two cases. The former one is representative of a sailboat mast at 15 kts, the latter one of a car moving at 100 km/h. Even if two bodies were identical (which they are absolutely not), the two airflows at such different Reynolds numbers cannot be directly and acritically compared.
This is what DCockey has been trying to tell you.
So, you have a scale model - great! Now you can perform few experiments and see where the truth (approximately) is. Just remember to scale the speed accordingly. You have to ensure that the Reynolds number of the two airflows (real stuff vs. scale model) is the same, in order to get similar airflows and comparable flow data. Let's ignore the laminar/turbulent issue for a moment.
The speed-length relationship which has to be satisfied is:
Vmodel * Lmodel = Vfullsize * Lfullsize
So if you have a 4:1 scale model, for example, you have to test it at 4 times the wind speed seen by the full-size boat. I hope the scale of your model is not too small, or you'll have big problems with laminar to turbulent transition, which might make your test model data unreliable.
I have seen the pdf presentations of your rig in this thread:
http://www.boatdesign.net/forums/sailboats/aftmast-rigs-623-38.html#post663229.
Regardless of the outcome of this (pretty much theoretical) discussion, I want to congratulate with you for the job done.
Cheers
