I always thought that stainless steel 316 is not magnetic
BertKu
Senior Member
Joined
May 18, 2009
Messages
2,521
Reaction score
47
Location
South Africa Little Brak River
I had a shock when I tested what stainless steel 316 was, to see whether my supplier gave me 316 or 304. I used a normal magnet and the 304 and 316 did not attach itself to the steel. However when I took an strong earth magnet, it was sticking somehow to the 316. Was I fooled by the supplier ? Is there an easy way to check whether 316 is really 316?.
This is quite normal. There is a slight magnetism also in the austenitic steels; more so in cast than in rolled material. The degree of difference lies in your "somehow". There is no simple and easy way to validate the composition.
Drop in into some wet salt for a couple of weeks and see what happens.
^Thank you, at least I don't have to crap all over the supplier.
Bert
Yes, that I can only do when it is not made into a long taking product. Only for some off cuts I will do that. Thanks, it is indeed the easiest, just a long wait for the result. Thanks it is indeed a way to figure it out.
bert
Cold working and welding can convert austenite to martensite which is magnetic. Also, the nickel content on 316 is from 10% to 14%, which varies the residual magnetism.
Thank you Gonzo.
