Hydroplane
Discussion in 'Boat Design' started by dmgetz14, Jan 31, 2012.
  1. dmgetz14
    dmgetz14 New Member
    I would like to build a hydroplane that would be able to achieve somewhat of a plane with a 3-5hp motor on the back but be able to accomodate up to a 10hp. If this is possible, does anybody have plans?
    If i were to build one from scratch, what type of wood would be best? I would then cover whatever material with a fiberglass sheet and marine epoxy.
  2. hoytedow
  3. messabout
    messabout Senior Member
    Rob White and Sons have plans and instructions for a 16 foot by 43 inch stripper that claims to plane two adults with 4 horse power. I'd be skeptical if the claim was from someone else. Robb, now deceased, was a most inventive and industrious guy who pretty much proved his claims. In this case I think that the boat will do what they say.
    Check this out at www.robbwhite.com
  4. FranklinRatliff
    FranklinRatliff Previous Member
  5. Plywood Tom
    Plywood Tom Junior Member
    I built a 10' racing pram about 15 yr ago, it planed at about 12mph with a 5hp air cooled Sears engine.
  6. hoytedow
    What was the total weight?
  7. Plywood Tom
    I never weighed it, but I would guess about 125#. It was 1/4" plywood. I would post a pic, but it is not on the net.
  8. hoytedow
    I should have said, "What was the total weight, loaded?".
  9. Plywood Tom
    Boat 125#
    Outboard 35#
    Boy 80#
    _________
    240#
    Again, these are guesses leaning to the heavy side.:)
  10. Jimboat
    Likes: 16, Points: 18, Legacy Rep: 130
    Jimboat Senior Member
    The MiniMax should plane with 5hp at 10-15mph, depending on your weight. Would be better with 10hp, though.
  11. hoytedow
    So, you got it to plane with 48# per hp. I can see that happening. My first boat did about 10 mph with a 5 hp sears but I weighed about 142# with 24 sf flat bottom and angular bow to total length of 8 ft. total weight of hull was ??? I don't remember. :(
  12. johneck
    Likes: 14, Points: 18, Legacy Rep: 117
    johneck Senior Member
    check this out
    www.ccwbra.com/
    Relative new class that uses 6 HP Evinrude/Johnson 2 stroke outboards as the only allowable power.
  13. SamSam
    SamSam Senior Member
  14. mydauphin
    mydauphin Senior Member
    I have an 18' foot canoe that will plane at 18knots with 2 relatively overweight guys on it. SO that is 160lb for canoe and engine, and about 400 for OW guys. So 560 lb with 5hp.
  15. rubyjeaan
    Likes: 2, Points: 0, Legacy Rep: 20
    rubyjeaan Junior Member
    Racing hydroplanes
    I've built many c-stock, d-stock,and fe class in the 80's and 90's. The boats must be built light, okume ply & okume sticks. Ply is 1/8" max. C-stock will reach a speed of about 70 mph. The FE or formula E will reach 135. Don't know were to find good plans anymore. I quit racing because the Ins. just got to high. Hope this helps...Michael..
