hydrdynamic analysis in ansys aqua
Discussion in 'Hydrodynamics and Aerodynamics' started by puma xalxo, Apr 24, 2015.
  1. puma xalxo
    puma xalxo New Member
    Hiii
    i am currently working in aqua i have ship design of IGS format i can import in aqua ans mesh done easily but when comes to solution it shows error "mass matrix not found"
    which format of that model (model from rhino i have exported) i should to get the result .
    please help me
  2. Ad Hoc
    Likes: 1,936, Points: 113, Legacy Rep: 2488
    The clue is in the error message.
    You must define the material proprieties, such as the density, to prevent this error message occurring. It is not about cut-n-pasting from one program to another. You need to understand what the software is doing...if you don't.....you'll make a big mess.
  3. puma xalxo
    now the error is coming "intersecting surfaces"
    help me to repair that
  4. Ad Hoc
    Read the manual and understand the theory. Then once you have done that, start with simple examples with known solutions.
    If you can't do that or have the time...change jobs.
  5. TANSL
    Likes: 929, Points: 123, Legacy Rep: 300
    The first thing you need is to build a correct model and the error message that appears is saying exactly this: "your model is not correct", because you have at least two surfaces intersect each other.
    You have to work with the program you used to create your model, edit surfaces and checking that each end where the contiguous surface starts. Is often preferable that there is a gap between them to intersect each other. It may help you work only with one side and then establish that the surface is symmetric about the centreline plane.
    If you could upload your model's file would be easier to analyze what happens to you.
  6. puma xalxo
  7. TANSL
    I made some modifications to your model. Hydromax calculates correctly with it. Try it.
    The best way to export / import files is in igs format.
    • VLCC.msd
      VLCC.msd
      File size:
      17.4 KB
  1. DogCavalry
  2. Umar Farooq
  3. OhMyBrain
  4. IngLaTorre
  5. lunatic
  6. Rounak Saha Niloy
  7. tuhin.name
  8. DogCavalry
  9. thenavalarch
  10. Binh
