Human powered propulsion - heavy duty & long distance
Discussion in 'Boat Design' started by icetreader, Jun 13, 2005.
  1. icetreader
    Likes: 1, Points: 28, Legacy Rep: 12
    icetreader Senior Member
    Intrigued by the discussion about propulsion for a human powered boat that would cross the Pacific I asked myself what was the traditional approach to moving heavy human-powered boats over long distances.
    The answer was sculling - from the Venetian Gondola to the Chinese Yuloh, the Japanese Ro etc: It has worked for centuries, and enables a single person to move large size boats loaded with passengers and goods across long distances.
    http://www.simplicityboats.com/yulohpage2.html
    The advantages are:
    Simple design, using all the main groups of muscles in the body (reduced fatigue), the blade generates continuous propulsion.
    Sculling requires the boat to be more stable than rowing, paddling or pedaling do, but that's possible to achieve with a multihull design.
    Any thoughts?
  2. cyclops
    cyclops Senior Member
    How much energy is lost due to 2 hulls going not straight? Or drag factor at 1 mph?
  3. CDBarry
    Likes: 33, Points: 28, Legacy Rep: 354
    CDBarry Senior Member
    You are correct. Sculling is more efficient than rowing, since it uses lift vs drag.
  4. icetreader
    Cyclops,
    I don't know the answer, but I suppose that since two straight hulls offer better directional stability than a single hull with curved lines the loss would be minimal.
    As for drag at low speed, in average twinhulls have about 25% more surface area than monohulls of same displacement, and this is meaningful especially at lower speed but the twinhulls' better directional and lateral stability compensate for this under "real world" conditions.
    CDBarry,
    I'm sure there have been studies on improving this type of propulsion, for example by introducing some flexibilty it the "tail".
    One can only be amazed from what fish and marine mammals achieve with tail propulsion.
    Yoav
  5. sideditch
    sideditch Junior Member
    Not much: because the relief of exit off sets the drag. And as the speed increases, depending on the draft, the "drag" creates lift such as a 'ski' craft and actually decreases the power needed and results in greater speed.
    Assuming power other than wind is used of course.
    It is a good time to be an explorer in nautical design for boat design as we have seen it in all of history till today remains in the DARK AGES.
    Tiny Bubbles, that is all the water needed to move at high speed in water born craft, notice the carefull omission of 'watercraft'.
    Regards,
    Sideditch
    ps Who cares if you are using lawyers for propulsion; you just wind them up and they go on for ever.
  6. Bergalia
    Likes: 40, Points: 0, Legacy Rep: 254
    Bergalia Senior Member
    True, but at what cost... and can you be sure they'll pull in the same direction...:mad:
  7. harlemriverman
    Likes: 7, Points: 0, Legacy Rep: 182
    harlemriverman Senior Member
  8. Sander Rave
    Likes: 7, Points: 0, Legacy Rep: 59
    Sander Rave Senior Member
    <<Sculling requires the boat to be more stable than rowing, paddling or pedaling do, but that's possible to achieve with a multihull design.>>
    Still don't know how to quote...
    If you got the hang of it, you don't need a stable boat. You just have to balance your weight in the right "swing". If you are talking about energy and efficiency, you don't want the boat to rock, this means loss of energy...
    In my experience sculling is great to produce torque, low speed, high mass movement. If you ask me how I want to cross a large wet area by human power, I'd prefer rowing.
  9. lewisboats
    Likes: 128, Points: 0, Legacy Rep: 1603
    lewisboats Obsessed Member
    "[QU0TE=Sander Rave]
    [/QU0TE]"
    Hit the quote button then just edit the stuff between the quote boxes down to what you want to quote and put your message after the end quote box.
