Hull speed
Discussion in 'Boat Design' started by HJS, May 9, 2010.
  1. sharpii2
    Likes: 310, Points: 83, Legacy Rep: 611
    sharpii2 Senior Member
    No.
    I mean the Length of the Water Line.
    That is about the best indication of potential Hull performance.
    There are other factors too. They are important but less so than the Waterline Length.
    Having a wide transom is definitely one of them. Having a low Displacement/Beam ratio is another.
    Now, the Length of the Waterline while sailing is far more important than the Length of it while the boat is sitting level.
    Early rule beaters had very short Water Lines, while sitting level. Once heeled, the Water Line got much longer. And it was that one that mattered.
  2. Ad Hoc
    Likes: 1,570, Points: 113, Legacy Rep: 2488
    This is a totally different realm to resistance per se.
    That is about manipulation of a rule, the way 'length' is measured' in said rule, to gain an advantage, that is all.
    Skyak and clmanges like this.
  3. gonzo
    Likes: 1,619, Points: 123, Legacy Rep: 2031
    There seems to be confusion between resistance of a hull and "hull speed". The curve for hull resistance will have an upwards inflexion at approximately the "hull speed" regardless of shape for what is usually referred as displacement hulls.
  4. jehardiman
    Likes: 1,077, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    HJS and gonzo like this.
  5. Tedd McHenry
    Likes: 8, Points: 8
    Tedd McHenry Junior Member
    You're probably right that it's informally used that way. But it has a formal definition. Hull speed is when the Froude number is equal to sqrt(1/2π).
    Will Gilmore and DCockey like this.
  6. kerosene
    Likes: 190, Points: 63, Legacy Rep: 358
    kerosene Senior Member
    doc can be found here
    Small Craft Engineering: Resistance, Propulsion, and Sea Keeping https://deepblue.lib.umich.edu/handle/2027.42/91749
    DCockey and clmanges like this.
  7. CT249
    Likes: 186, Points: 63, Legacy Rep: 215
    CT249 Senior Member
    Interestingly, when one reads accounts by George Watson and WP Stephens, for example, they actually give different accounts about why their boats developed long overhangs. They were not ignorant of the measurement factor, but they tend to speak of the longer overhangs as the logical outcome of moving to a shallower, lighter hull form and reducing wetted surface area. As Watson said, once one goes to a shallow, wider hull then overhangs start to become the best way of creating fair hull lines, at least in a boat built to 1890s technology and concepts.
    At a more practical level, a long overhanging counter had the huge advantage that you could reach the end of the boom, for stowing the sail, adjusting it, or putting in reefs. A long bow overhang allowed for a shorter, stronger and more easily worked bowsprit. Given that design and technology meant the use of vast rigs (by our standards) in many classes, and the difficulty of handling hemp or manila lines and cotton sails, bringing the deck closer to the end of the rig had a lot of practical advantages.
    Designers like Clayton or Watson were not great fans of the rating rules that relied on waterline length - they were among the large group of top UK designers who formally asked the RYA to change the rule to create more "wholesome" boats, in a group submission about 1896. They were frank and outspoken against the rule, and about the way it could be beaten, so they were not trying to hide anything when they stated that the primary purpose of long overhangs was for reasons other than rule cheating.
    In the more extreme classes, after about 1896, straight-out rule beating did become an object. But now that we can get access to lots of archived documents, the conventional wisdom that long overhangs were only there to cheat the rule doesn't really stand up.
    Doug Halsey likes this.
  8. Ad Hoc
    Interesting anecdotes, thanks for that.
    I think one would need to take a step back, and view through the prism of 19thC understanding of hydrodynamics. I suspect they didn't think it was manipulation of rules, for their aforementioned reasons, but unknowingly.
    Given hindsight of today's greater understanding of hydrodynamics and its influences, I suspect they would concur re: manipulation for improved performance, rather than maintain their original ascertain.
  9. DogCavalry
    Likes: 1,500, Points: 113
    DogCavalry Soy Soylent Green: I can't believe it's not people
    Bluebell, you're some kind of mojo. 11 years of silence, you comment on it, and it takes off.
    I think what Gonzo meant is that there's a point in velocity/ power curve, where the second derivative of that curve becomes rather abruptly negative.
  10. BlueBell
    Likes: 895, Points: 113
    11 years and 1200 views!
    jehardiman and DogCavalry like this.
  11. jehardiman
    And 1200 people (give or take), who decided not to address the question "Has anyone studied how the longitudinal metacentric height is proportional to the resistance in speeds between FnL 0.3 and 0.5?".... Sooo, this is not an area of concern, or it is a doctorial thesis awaiting a brave soul. (FWIW, I see a quick and dirty one using the Series 62 Data back-calculating the required longitudinal metacentric height ... just tossing that out there.)
  12. HJS
    Likes: 121, Points: 43, Legacy Rep: 288
    HJS Member
    Two boats with the same total weight, the same length and width in the waterline and over all.
    The big difference is the shape of the transom and thus the longitudinal and transverse metacenter radii.
    This in turn creates less resistance in the speed range around "hull speed".
    JS
  13. TANSL
    Likes: 683, Points: 123, Legacy Rep: 300
    Of course, both boats have different KMl, but a 20% difference seems too much difference, since the inertia of the float with respect to the transverse axis is not great. This is just an assumption since I have not performed any calculations.
  14. HJS
    HJS Member
    My measurements are calculated, no guesses.
    As I mentioned at the beginning, I have other examples with the rowing boats.
    JS
  15. TANSL
    I think you are giving me the reason when, to refute my "assumption" you are using a totally different figure from the one (post #27) I have commented on. But the subject is not the least important. As you say very correctly, the value of KMl is different, although it would not have been necessary to calculate anything.
