- Yes it looks the generators are way too big, I started on the bigger end to be conservative. They should be of high rating (continous), commercial grade, and they are usually bigger than leisure rating. What do you normally do to chose proper gensets (not engines) for electric drives ?
- I really do like making a catamaran or trimaran, or even a SWATH. I have proposed this to the client but in his view a wave-piercing monohull is a better option...
I like
this one as an example. Even thought of shock absorber hull to isolate the platform. It should be able to operate world wide, even at higher latitudes for long range so just solar panels I am afraid won't be enough(?). Thus the large fuel tanks requirements (5-8 m^3 ??).
It will be exposed to open sea water and nasty weather, so a cat or tri becomes less attractive having to maintain roll and pitch angels to less than 10 deg ideally for most of the time.
