Hull Design of a multihull passenger ferry
Discussion in 'Boat Design' started by NITHIN BABU, Mar 15, 2017.
  1. NITHIN BABU
    NITHIN BABU Junior Member
    what all we have to consider while designing HULL of a multihull passenger ferry?
  2. TANSL
    The normal thing is to have a SOR that, among other things, will define the type of hull to use. So, in my opinion, the first step would be to write a SOR and, with it, draw a GA plane to check if there is space on the ship for everything it has to carry.
  3. NITHIN BABU
    I have prepared GA and all, I want to know is there anything to consider while designing double Hull
  4. TANSL
    As I have told you, what you should prepare is the SOR of your ship, as detailed as possible. There are, indeed, many things to keep in mind, regulations to be fulfilled, scantlings, stability, security, comfort .... The same things as in a mono-hull, if this helps you.
