Hull design - CAD drawings
Discussion in 'Boat Design' started by congellous, Sep 3, 2013.
  1. rwatson
    rwatson Senior Member
      File size:
      17.9 KB
  2. Deering
    Likes: 25, Points: 18, Legacy Rep: 44
    Deering Senior Member
    The forward foil would likely introduce a wake of turbulence which would render the aft foil ineffective. Perhaps a single foil slightly forward of your LCG, and use a trimable prop aft to provide overall trim control.
    You might look at this system for ideas: http://www.hysucat.co.za/another_page.html
  3. congellous
    congellous Junior Member
    Hmm, back to the drawing board...... The idea, however, is to cruise at minimum speed to be on the foil, with this in mind and the distance between them is there any other configuration - 4 struts ? 3 maybe
  4. congellous
  5. congellous
    hull 2
    I have submitted a redesign with a front foil that would displace the flow between the catamaran hulls in the "tunnel" with a wide foil at the back, would this work ? If, while foil borne it became a plane type hull this would still be a reduction in drag....I'm also wondering if this could be powered by impellors in the cat hulls at the rear like a jet ski
  6. DCockey
    DCockey Participant
    How will the height and attitude of the boat be controlled when foil-borne?
  7. Ad Hoc
    Likes: 2,003, Points: 113, Legacy Rep: 2488
    Those HYSWAC-thingy type boats, they are no different. No control when foil borne, they are passive.
  8. Mr Efficiency
    Obviously it depends on how much lift the foils develop, in the case of the foil assisted cats you refer to, the whole weight of the boat isn't foil supported ever, when you have foils that project deeper under the hull, in theory it could be.
  9. congellous
    I was hoping it would sort of plane on the base of the cat hulls not really out of the water ? It's only intended for inland waters, rivers and fair weather and I was thinking the foils could be folded up....
  10. BMcF
    Likes: 226, Points: 63, Legacy Rep: 361
    BMcF Senior Member
    Which ones are you referring to? The HYSWAS (MAPC's) and Navatech's HYSWAC were both entirely dependent on the active control of foil lift to acheive and maintain stable flight. Same as true of the foil-asssisted DAT we built...a control system hiccup underway meant an immediate plough-in.
  11. Mr Efficiency
    Oops, looks like I confused HYSUCAT for HYSWAC !
  12. Ad Hoc
    See, so many acronyms to shake a stick at...there is always one that picks you up on it !! :D
    The ones designed, in general, by the South Africans, such as Prof Hoppe, Teknicraft et al. Thiers are always passive.
  13. BMcF
    BMcF Senior Member
    That they usually are. ;) A couple of them have been built with active trailing edge flaps in the main foil and active tabs or interceptors on the transom, they are the exception rather than the rule for that configuration.
  14. DCockey
    DCockey Participant
    What determines ride height/sinkage and pitch/trim at speed in the ones with passive controls?
  15. Deering
    Passive but adjustable. The aft fins can be set at different attitudes to adjust trim. Once set, they are fixed in place, so they probably only function optimally at a narrow speed range.
    I've thought that trimable outboards might accomplish the same effect on a small boat, but could be adjusted dynamically.
