Hull (Bottom) Thickness-Does It Matter?
Discussion in 'Wooden Boat Building and Restoration' started by Rollbar, Aug 24, 2018.
  1. Rollbar
    Likes: 1, Points: 3
    Rollbar Junior Member
    Hello, soon (in a few months) I'll be building a Spira Albion 19' (first time builder).
    Plans call for a 5/8" on the bottom of the hull and I was wondering if it is worth using 3/4" instead/just wanting a stronger or thicker hull.
    If not maybe just the front part of the hull with 3/4" for beaching/longevity etc. and fair it down to meet the 5/8" for the rest of the hull.
    Is it worth it since I'll be glassing the hull (6oz)-2 layers maybe)?
    Thanks for your help/opinion,
    JB
    http://spirainternational.com/study/AlbionStudy.pdf
  2. Blueknarr
    Likes: 461, Points: 83
    Blueknarr Senior Member
    welcome to the group
    Congrats on biting the bullet and starting your first build.
    3/4 plywood will be much harder if at all possible to flex into the bow's shape.
    It will be impossible to scarf two thickness of plywood and have them flex smoothly.
    5/8's is pretty stout for a 19 footer.
    Adding extra fiberglass is an easier way to achieve greater impact and abrasion protection.
    Good luck on your build.
  3. JamesG123
    Likes: 77, Points: 28, Legacy Rep: 10
    JamesG123 Senior Member
    Anything that can penetrate or make 5/8" fail is probably going to make 3/4" fail too. And like "Bluekarr" mentions, its pretty hard to work with unless your design is faceted from flat sheet.
  4. Rollbar
    Likes: 1, Points: 3
    Ok thank you very much.
    Been reading up on a lot of posts to learn.
    Thanks again,
  5. flame
    flame Junior Member
    Spira Albion is a Dory, so the bottom is more or less flat with a skight bend towards the bow, that should be manageable
    the sides are sitting on the upper surface of the bottom, so that doesn't need the plans to chage, another pro
    the center of gravity will not move significantly due to the additional weigth, so impact will be minimal
    weigth will be a bit higher ... you feel it when you carry the hull to the water with your buddies, but you'll manage
    the question really is: cui bono? what forces are you expecting from below (or above ... through the false floor) that would call for 3/4" ... if any the bottom will slide on something ... for that it doesn't matter if 5/5" or 3/4" .... price?
    how's going sofar with your build?
  6. romeomikehotel
    Likes: 3, Points: 3
    romeomikehotel Junior Member
    I believe Spira spaces his frames nearly every 2’.
    If speeds were in the 55-65 range, would 3/4 be a significant advantage over 5/8?
  7. BlueBell
    Likes: 1,217, Points: 113
    Nope.
    romeomikehotel likes this.
  8. romeomikehotel
    Likes: 3, Points: 3
    Would that opinion change if the requirements were to run 55-65 through 2-3’ chop. Assuming some slamming now and again at speed?
  9. Mr Efficiency
    Seriously ? 55-65 (mph ?) in that boat in 2-3 feet chop, completely unrealistic, don't worry about the boat breaking, the passengers would be medivac jobs.
  10. romeomikehotel
    Likes: 3, Points: 3
    Lol no not in that boat.
    Just hypothetically. Assuming a boat that’s not a flat bottom.
    Thinner ply is easier to work with and likely saves around 100lbs if a hull bottom is 5/8 instead of 3/4.
    But is that 100lbs and ease of use a worthwhile trade off in an extreme use environment.
  11. Mr Efficiency
    100 lbs sounds like a lot for 1/8" of ply, but it depends on how close spaced stringers and bulkheads are, as to whether it would help, the main thing would be to have a nice stiff bottom, rides better, and over time ply does lose a little bit of stiffness with repeated slamming loads.
  12. romeomikehotel
    Likes: 3, Points: 3
    So I was ballparking a bit. 3/4” is 68.1lbs a sheet and 5/8” is 56.6lbs a sheet.
    Spira’s larger plans call for around 7 sheets for the Hull bottoms so that puts it around 80lbs.
    Which I guess probably answers my own question, it’s probably better to use 3/4”
  13. DCockey
    Likes: 677, Points: 113, Legacy Rep: 1485
    DCockey Participant
    Look at the Spira Albion study plans. http://spirainternational.com/study/AlbionStudy.pdf The Bill of Materials calls for 4 sheets for the bottom, not 7 sheets. And not all of the plywood will be used in the boat. There will be some scrap. So the weight difference will be 50 lobs or less.
  1. sdowney717
  2. gunter
  3. Lightfoot
  4. boony
  5. WhiteRabbet
  6. Josh Goodswen
  7. Joe Earl
  8. Travis Grauel
  9. AAnderson
  10. Floatything
