How to quiet noisy exhaust?
Discussion in 'Diesel Engines' started by Brands01, Jan 12, 2010.
  1. mark775
    mark775 Guest
    Kaluvik, nice work. You need to deal with the moisture problem evident in the third pic and I would not leave the bare plywood bulkhead in the first pic. Everything else I see looks to have been done by someone who cares (you).
    What you did doesn't adress the intake noise they're talking of, tho.
  2. Kaluvic
    Likes: 3, Points: 0, Legacy Rep: 32
    Kaluvic New guy
    Thanks Mark
    Like I said...it may not be relivent....I just wanted to post something with a picture.
    I'm anal about dry fitting everthing I do...that ply is now painted.
    Mark...Homer...do I know you...spend any time around Fairbanks?
  3. mark775
    mark775 Guest
    No. I've been there three times.
  4. apex1
    apex1 Guest
    Yeahh......this and that:
    seems not to be the same animal! I understand.
  5. Brands01
    Brands01 Senior Member
    Well the 10cm length of hose stopped the subwoofer effect, but I suppose now that I've identified the cause of plenty of noise, its worthwhile trying to minimise it by experimenting with different lengths of hose and mufflers.
    I was thinking that an automotive muffler on the intake might be effective for its passive noise cancelling, but it may restrict airflow too much. Any thoughts on that idea?
    Barney
  6. apex1
    apex1 Guest
    Easy to measure Barney.
    Assuming you did´nt change anything and the boat is in running condition, you put the hose on and have a ride in calm waters. If there is no smoke, continue. Set the throttle fix and put the hose off. Any change in rpm ?
    Remember the setting.
    Now put the (cheap) Rover air filter on it and do the same run, same rpm, and get it off while running.
    Watch for smoke while the filter is installed, it would be a sign of a choked inlet.
    But you can have it easier.
    When you are fine with 10cm of hose for a wide range of resonance, you need just another diameter of any length to get rid of almost all of the rest. A plain metal mesh "airfilter" (in fact they hold just mice, rags, and t- shirts out), wider than the inner diam. of your hose, does it.
    The Rover "oil" air filter has the same effect, but I assume the inner diameter is smaller than your inlet. then forget it.
    And if there is a 90° or worse change in the direction of airflow it is not the way to go. I do´nt have the data at hand, but I remember that a 90° knee is about 20% or more restriction in air flow!
    The muffler idea is one you should quickly forget. Exhaust gas pressure has no problem to overcome resistance of some severe amount. The same resistance on the inlet chokes your engine to death.
    Regards
    Richard
  7. Landlubber
    Landlubber Senior Member
    ...if I may go back to one of my past posts regarding the water setarator type mufflers that we use on gen sets.......how big an engine can they cope with, I have only used them on small engines (say 25hp)?
  8. apex1
    apex1 Guest
    Lubs
    Barney was asking for a muffler on the INTAKE !!
    The separator types I have installed cope wit 100hp easily. Dunno if there are bigger sizes around, we do´nt use them anymore.
  9. Frosty
    Frosty Previous Member
    How big is the gen ? is it a turbo?
  10. apex1
    apex1 Guest
    Gen? Who talks about a genny?
  11. Frosty
    Brand --I guess your bid on the Landrover filter failed.
    A land rover is a hardy vehicle and is in every rough terrain countries. They are meant to be the most reliable vehicle capable of things others would not dream of . There filters are built with similar enthusiasm. a huge oil bath, with an intake surrounding the approx 10inchX 14 filter. These filters were made to supply clean air to a 2 liter engine crossing the Sahara. The intake is approx 6 inch dia, you can get your hand in and wipe them out.
    To listen to suggestions that it would restrict air flow to a 38 HP is-- well.
    If your 10cm pipe shuts down noise to an acceptable level then its done.
    The rubber absorbs the noise, if you used a metal pipe your would just move the source of the noise.
    Im gonna take my air cleaner off my cars I might get a performance increase!!!!!!!!! I wonder why they fit these useless air clogging devices.
    Google filter boxes for performance, or in a similar kinda way intake plenum chambers.
  12. Frosty
    Read the word GEN
  13. apex1
    apex1 Guest
    Well got the GEN.................from Lubbers post.
    Air filters, dear Frosty, capable of keeping Sahara sand out of a 2 ltr. engine have a serious resistance! The same filter on a 1,5 ltr. marine Diesel is a nonsense. It restricts air intake period!
    The rubber does nothing in resonance avoidance! The length of the hose is it.
  14. Frosty
    Not my ball park! Oh boy.
    Your thoughts on filters is Sunday afternoon boy racer mechanics.
  15. apex1
    apex1 Guest
    Ok
    I agree..................
    senseless to teach the invalid.......
