How to input lines plan in maxsurf, which is created in autocad?
Discussion in 'Software' started by Ghost Boy, Oct 6, 2019.
  1. Ghost Boy
    Likes: 1, Points: 8
    Ghost Boy Junior Member
    Hello,
    I have drawn lines plan from offset. It is created in Autocad. Now I wanna import this lines plan in Maxsurf to do resistance and other hydrostatics calculation. How can I do this? I am not very comfortable with Maxsurf. I am new in Maxsurf.
    Thanks in advance. :D
  2. TANSL
    Likes: 958, Points: 123, Legacy Rep: 300
    You can export them in dxf format but you must first put the lines in the space in AutocAD. You can also create the surface model in AutoCAD and export it in igs format to MaxSurf.
    If you don't get it, send me the AutoCAD file you have to see if I can help you.
  3. Ghost Boy
    Likes: 1, Points: 8
    Thank you sir. Sir, can you please refer me any video link?
  4. TANSL
    I don't know any videos on this subject.
    Can you show me your file in AutoCAD?
  5. Ghost Boy
    Likes: 1, Points: 8
    Sir, Here it is.
  6. TANSL
    You need to put the frames in their true place in space. Something similar to what is seen in the attached picture. With these lines as a base, you can build the 3D surface model, in AutoCAD or Maxsurf (if you export them as 3D Polylines) Body Lines.jpg
  7. Ghost Boy
    Likes: 1, Points: 8
    Thank you, sir. Please give the Autocad file.
  8. TANSL
    I'm sorry but I haven't done anything with your drawing. The image refers to one of my ships. If you want it, I can give it to you.
  9. Ghost Boy
    Likes: 1, Points: 8
    OK, Sir. Please give me that.
  10. TANSL
  11. Ghost Boy
    Likes: 1, Points: 8
    Thank you, sir :D
  12. tapan khandelwal
    tapan khandelwal Junior Member
    Hello sir, i am doing passenger ferry but how to draw lines plan for it. because i have NPL series for this Fn is 1.2 so i follow this series, parentship is not available for my owner requirement
    no of passenger=130
    route=kochi port to goa
    operating speed is 12 knots
    cars= no
    how can i find out ferry according to requirement. help me please and how to calculate the proper value of length, beam, depth, and draft
