Michael Gray
New Member
- Joined
- Jul 9, 2020
- Posts
- Reaction score
- Location
- USA
I am refitting an outboard boat and I want to place the engines aft on a bracket to close the transom. Is there a quick and dirty set of calculations I can use to estimate what the force will be on the stern? For instance, if I have the waterline marked when the boat had 1300# of outboard on the transom, and I want to move them further aft by 30", can I calculate how much weight I could put in the hull, at the transom, to simulate where the water line will be? My thinking is, add the appropriate weight, float the hull, observe waterline change, then move some items around and forward to compensate and maintain previous waterline.
