How to Design a modern Yacht
Discussion in 'Sailboats' started by CarlosK2, Nov 26, 2024.
  1. CarlosK2
    Likes: 122, Points: 63
    CarlosK2 Senior Member
    The knife-sharp bows that were seen in the world of high competition until yesterday afternoon (-2015) make no sense: Upwind the sailboat is heeled and Downwind we want a spoon-shaped bow and even more so if the stem is vertical.
  2. CarlosK2
  3. CarlosK2
    Transquadra 2017
    Finish line
    First we see Alex Ozon with a Plywood Epoxy "Bepox 900" and second JPK with a "JPK"
    Well no, in this video without sound you can only see Alex with the Bepox 990 that worried so many because it was unbeatable due to its contained wet surface compared to the then dominant trend. Less is more.
  4. CarlosK2
    (1 Ton Plywood Epoxy Surfboard for an old fogey)
    What are the differences in nuance with a "Bepox" 2015 or a new "JPK" 2025
    LWL is smaller and therefore the D/L ratio (ca. 150) is higher, but it is much easier and more comfortable to hoist almost 30 square meters per Ton
    And my Surfboard is not looking for speed or to win any race: the design is focused on Comfort and Safety which in the end translates into not using an autopilot or using a very cheap one
    And the cockpit is more comfortable for an old fogey
  5. CarlosK2
    and ...
    it has two gears to stop safely:
    plan A) hove-to like a yawl
    plan B) hove-to without sails anchored in the sea with a sea anchor
    and another detail is that the rudder and the centerboard are raised and so on the one hand they stay clean and, on the other hand, the small sailboat can rest on a nice sandy area
  6. CarlosK2
    (I assure you with complete sincerity that I have been wanting to stop writing for months, and I almost managed it thanks to the magnificent ignore function of this forum but on the one hand I get distant echoes and on the other hand I obviously really like talking about my dream surfboard)
  7. CT249
    Likes: 266, Points: 83, Legacy Rep: 215
    CT249 Senior Member
    You appear to have the completely incorrect belief that there is only one "dominant trend". The wide, high wetted surface shapes are not really a dominant trend in world sailing - only in some of the most publicised events.
    If you look at what people are really sailing you will learn that J/boats, TP52s and many others don't follow the "dominant trend", which isn't really dominant.
  8. gonzo
    Likes: 2,386, Points: 123, Legacy Rep: 2031
    If you want a surfboard, why are you so obsessed with sailboats?
    Is it that you haven't understood the difference between a surfboard and a sailboat?
  9. CarlosK2
    This vice is worse than smoking and then trying to quit smoking
    Last night I realized (Savitsky 1964) that instead of tilting the vector H towards the stern it is better to tilt the vector H1 towards the stern, the first way results in a resistance of 1218 Newtons and calculated in the second way it results in 1250 Newtons because H1 is more inclined towards the stern due to the fact that the Angle of Attack is greater than the trim (t) of the hull because it is the sum of the trim plus the shape of the hull
    0.60 Froude
    t = 2°
    A) 3000 Newtons
    H1) 3600 Newtons
    H2) 6400 Newtons
    B) 900 Newtons
    The sailboat in this still photograph is sailing in "young adventurer mode": 75kg + 25kg belongings, loaded with 90 days x 2000 kcal/day of food and 70 liters of fresh water
  10. CarlosK2
    Jib: 9
    StaySail: 7
    MainSail: 14
    I was 'sailing' a lot last night with Numbers
    once again worried about whether a 9 square meter jib would be too little and maybe a 20-24-30 square meter gennaker
    To my delight I see that the quest for speed pales in comparison to functional beauty
    in 10-30 knots of wind, Downwind, the sailboat does 5 knots (0.35 Froude, which is "the real world hull speed") 6 knots (0.40 Froude, which is the theoretical hull speed) 7.5-8 knots (which is the "carene speed", "carene" around 150 D/L depending on the mode) and (StaySail+ MainSail second reef): 9 knots with 14-18 knot ... Surf
    That is, in complete harmony with Force 7 waves that sail at 14-18 knots
  11. CarlosK2
    With the sailboat anchored, the sailor sleeps under goose down in the bow in a enormous bed
    And while sailing, the sailor sleeps in a sleeping bag on top of the 60 cm wide food cargo box and large chart table between the two closets without doors, one for dry clothes and another for wet clothes, that is, the sailor sleeps across so he doesn't roll with the roll of the sailboat
    And who is in charge of the helm?
  12. CarlosK2
    Autopilots
    The cheap ones, supposedly cheap (ca. 500 Euros)* are actually very expensive for what they offer
    Two autopilots have recently appeared, one in California and another in Germany, which for around 800 euros 950 dollars, compete with the 1.5-2 K Euro autopilots
    Pelagic Autopilot Systems https://pelagicautopilot.com/
    Pcnautic Tiller Autopilot https://pcnautic.com/en/product/pcnautic-autopilot-tiller-pilot
    On the other hand, there are wind vane pilots between 1.5 and 6 K Euros
    But the question is neither the price nor the electricity consumption in the case of autopilots, but the functional beauty
    *: OMG: 670
    https://www.svb24.com/en/simrad-tiller-pilot-tp-22.html
  13. CarlosK2
    With superb and exceptional Pitch control, and wonderful Yaw control... the sailboat almost sails alone
    Let's not forget that Joshua Slocum sailed around the world without a windpilot or autopilot: simply by balancing the off-centre force of the mainsail with a jib on a bowsprit
    if a sailboat almost sails alone (thanks to its stable hydrodynamic balance on the Pitch and Yaw axes) then it only needs to control the imbalance created by the force of the mainsail
  14. CarlosK2
  15. CarlosK2
    The staysail boom
    The StaySail Boom serves a lot of functions and is one of the best inventions since cold beer
    It is used to trim the sail upwind: we can adjust the angle of attack, the camber and the twist, that is, what they now pompously call "3D trimming"
    On the other hand, it helps us to make the sail efficient downwind
    It also allows us to install a reef and turn the staysail into a storm sail
    And
    It is a wind vane in charge of steering the helm
    (Eric Hiscock, Cruising under Sail)
    StaySail Boom to tiller
