How to decide longitudinal & transverse BHD position for a Ship/Barge
Discussion in 'Boat Design' started by Farhad, Mar 31, 2018.
  1. Farhad
    Farhad New Member
    Dear Sir's
    I am a new member of this forum, currently assigned to do a scanting calculation for a box shaped barge given with principal dimensions and other data as follows: ( The assignment is just for my learning purpose)
    L (Scanting): 200 m
    Beam (mld): 36.0 m
    Depth (mld) : 11.9
    Draft (design): 7.9
    Draft (Scantling): 8.0
    beside these if the deck loading, Longitudinal & transverse spacing is known,
    How could I select the number & location of transverse & longitudinal BHD?
    How about location of aft and fwd collusion BHD?
  2. TANSL
    Your barge will probably need to comply with the rules of a classification society. See these rules that will clarify many things. On the other hand, the needs in ballast or other tanks, if you have them, will help you decide the number and position of some bulkheads.
  3. Ad Hoc
    Likes: 1,971, Points: 113, Legacy Rep: 2488
    Check what stability rules the vessel is designed to satisfy, and then run a damage stability analysis, using the IMO standards as guidance for minimum distance between WTBs as your first guide.
    Given in IMO/Class rules.
  4. TANSL
    damage stability analysis for a barge?. I don't think so. A study of floodable lengths would be more than enough.
  5. C2 Naval
    C2 Naval New Member
    Hi Farhad,
    As TANSL said in his first post, you should follow a specified Class Rules for a barge, mainly for its main dimensions and for Class Society purposes. As per this point, many of Class Society has different rules according the main particulars of the design (self propelled, ballast tanks, etc.), so you must define it before.
    As a general note and thanks to a past barge Projects (50m and 100m) a damage stability study was not required by the Class. Normally, you can find the necessary documents and drawings in the corresponding rules to apply.
    Do not hesitate to share your next steps!
  6. jehardiman
    Likes: 1,472, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Actually, a damaged stability analysis is dependent on what the barge is used for; I know for a fact that a berthing barge and one transporting certain hazardous materials require them here in the US. See 33 and 46 CFR.
    Even if there is no subdivision requirement, there may be a cost/deadweight/scantling/strength tradeoff. Depending on your cargo requirements and framing choice you may be able to tradeoff shell thickness/frame spacing/bulkhead spacing against fabrication cost/weight.
  7. TANSL
    @jehardiman, if you say so, I'll have to believe you but, frankly, I have serious doubts. Perhaps for a very special type of load, with a very special type of barge, it is necessary to make a stability analysis after damage but I am not able to imagine what that special case could be. Nor am I able to imagine that "cost / deadweight / scantling / strength tradeoff". Complementary information would be very interesting (keep in mind that I do not have the USCG regulations).
  8. Farhad
    Farhad New Member
    Thanks everybody for your kind support and advise. However I was quite away from conceptual design. From now on I came bay with full fledge. Need your kind advise again.
    Regards
    Farhad
  9. bajansailor
    Likes: 1,827, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Welcome back Farhad.
    Can you share some more details please of the barge that you did design?
    That was 3 years ago - I presume that you have graduated from college now?
    And what would you like advice on now - do you have another project that you are working on?
  10. Farhad
    Farhad New Member
    Hi Bajansailor
    That project I finish somehow with the help of my senior colleague. However that was my part time conceptual design stage, Now I will be working more dedicatedly on this
