How to check if engine running hours are programmed?
Discussion in 'OnBoard Electronics & Controls' started by AprilSky, May 29, 2025.
  1. AprilSky
    Likes: 0, Points: 3
    AprilSky Junior Member
    Recently I was looking for a repair tool for my boat and found a tool can directly modify the engine run hours.
    It all seems so easy in the video.
    I am a little concerned. Is there a way to check to see if the engine running hours has ever been modified?
  2. BlueBell
    Likes: 1,281, Points: 113
    No, other than service records.
    But if someone is going to alter the hobbs meter then they're
    going to alter the service records too... if they even exist.
    Why do you ask and why are you concerned?
  1. Lawrence101
  2. missinginaction
  3. sdowney717
  4. mbowser
  5. sdowney717
  6. sdowney717
  7. the brain
  8. oceancruiser
  9. Landlubber
  10. caslor
