How thick should my powerboat hull be?
Discussion in 'Fiberglass and Composite Boat Building' started by aqua, Oct 22, 2007.
  1. aqua
    aqua New Member
    Hey all. I have a 12' boat that i am redoing. I have the deck separated from the hull and i am replacing all of the old rotten wood with either nidacore or coosa....havent decided yet. Anyway on the bottom of the boat there was a 1/4" sheet of plywood cut and layed down flat on the bottom of the hull for additional support. My plans are to replace this with a standard stringer setup and I was going to reinforce the hull since it is only around 1/8" to 3/16" thick. What materials and how much could I use to try and keep the weight down to a minimum but still add enough strength to hit a few waves. It will have stringers placed about 12 - 15" apart. How many layers...what ounce....what kind. Would be using epoxy. thanks
  2. parnine
    Likes: 0, Points: 0, Legacy Rep: 4
    parnine New Member
    buy and read 'the elements of boat strength'
  1. mongo75
  2. Jason Penton
  3. garage monster
  4. Bullshipper
  5. Fishbonemarine
  6. Cjmac
  7. Anze
  8. Canunut
  9. reddeer04
  10. LowelandSystem
