How soon to paint over polyester resin
Discussion in 'Fiberglass and Composite Boat Building' started by burke, May 20, 2017.
  1. burke
    Likes: 1, Points: 8, Legacy Rep: 16
    burke Junior Member
    I will be applying an oil-based Petit EZ primer over a polyester above-waterline FG layup, then a polyurethane paint. How soon can I apply the primer??
    Thanks
  2. Mr Efficiency
    The application of the paint to the laminate may be less problematic that the primer/finish interaction, one-part polyurethane does not adhere well to alkyd undercoats unless they are fully cured, i.e. odour free. You will have a tacky surface for some time with the laminate (presumably unwaxed resin), but should be good to coat within a few days. Scuffing the surface a little to dull the surface slickness would help, but it will clog sandpaper.
  3. ondarvr
    Likes: 641, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    Some primers and paints don't bond well to the backside of an unprepped polyester resin surface, so that's another complication.
  4. Mr Efficiency
    I have never painted glass laminate with an alkyd primer or undercoat, so don't know how compatible, I've used expoxy primers, acrylic undercoat, polyurethane finish direct, without any failures. Epoxy would be the best way to go.
  5. ondarvr
    Depending on the exact resin, it will take a while for the surface to be come tack free enough for some paints to stick, others stick well to the still under cured surface. This is were type of paint and timing come into play. Epoxy would stick well to the fully cured surface, but may fail if it's still tacky.
  6. Mr Efficiency
    From memory, I have painted epoxy primer over a few days old laminate, with no nasty consequences. Mind you, here in sunny Queensland is climatically rather different to Washington State ! More like Florida.
  7. Mr Efficiency
    The laminate I speak of above was isothalic polyester. Done that on a few occasions. Still sticking.
  8. ondarvr
    Yes, various paints used in various ways will stick, not all will though.
    ISO typically cures fairly well on the back side after a few days, but depending on catalyst level, ambient temp and humidity, the surface may stay sticky much longer, not all paints can deal with this. I've seen paint stick for decades, and I've seen paint peel off in a few weeks. For about 15 years I painted the backside of large high pressure water filtration tanks, many per day, we never had a problem with the two part paint with no primer, they sat out side for many years (decades) and none failed.
  9. burke
    burke Junior Member
    Thanks all,
    Your first comment: I called Petit over the winter to ask if I could use a single part polyurethane or a latex enamel over EZ Prime Hi Build Undercoater 6149. They said yes. Just checked the Data Sheet and it said single or two part enamels OK.
  1. Pylasteki
  2. Jason Rodgers
  3. Laurance
  4. convincor
  5. Mark C. Schreiter
  7. fallguy
  8. SamC
  9. E350
  10. Rebel01
