fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Posts
- 8,975
- Reaction score
- 2,104
- Location
- usa
Au contraire
...But, your point is understood.
-Will (Dragonfly)
how far can he go?
Note: This feature may not be available in some browsers.
Au contraire
-Will (Dragonfly)
Across the English Channel - Gossamer Albatross and Gossamer Condor, designed by Paul McCready. The story is fascinating ...how far can he go?
When a boat moves through the water, it creates a series of waves by pushing the water aside.
@Rumars, for those of us who are uninitiated, could you please explain the initials you used in the post above. I don't know what SOF or HDPE or L:B ratios are.
Thanks.
-Will (Dragonfly)
The boat you choose based on prevailing conditions and live with the downsides the rest of the time. If you want to experiment make some prototypes in SOF by using cheap wood and PVC tarp. Don't be concerned about weight or durability, those aspects you can tackle after you have a good design.
A frame, like what you are talking about, should be easily built with only hand tools. You aren't talking about shaping large timbers or big bulkheads or fitting complex panels. A few light frames and stringers notched in. A little glue, some hand plane work and sanding.I also need to keep my tools simple, cheap and compact (e.g., jig saw or hacksaw instead of band saw).
Skin on frame is the way to learn, without power tools.Thanks! I'm looking for something simpler, that doesn't assume as extensive woodworking knowledge, but will ask and look elsewhere.
