How much glass is in a roll
Discussion in 'Fiberglass and Composite Boat Building' started by brokensheer, Jan 22, 2012.
  1. brokensheer
    Likes: 3, Points: 18, Legacy Rep: 14
    brokensheer Senior Member
    I know there aRE VARIABLES but for example in a roll of 1708 50" wide how much glass by square foot is in that roll?
  2. lewisboats
    Likes: 129, Points: 0, Legacy Rep: 1603
    lewisboats Obsessed Member
    according to here: http://www.shopmaninc.com/cloth.html
    the length of a roll is generally 125 yards but can vary from 110-130. You are looking at around 1575 sq ft for a roll. Or are you talking weight? If so you need to divide into yardage and multiply by the oz per yard cloth weight.
  3. gonzo
    Likes: 1,488, Points: 123, Legacy Rep: 2031
    Remember that it is 17oz per sq.yd and .75oz per sq.ft.
  4. Roly
    Likes: 23, Points: 18, Legacy Rep: 222
    Roly Senior Member
    So weigh it & do the math if it isn't a virgin roll. Allowing for core.
  5. brokensheer
  6. Frosty
    Frosty Previous Member
    I bought a kilo of glass the other day, he said it is 300 I dont know what that is but he said it will have about 4.5 sq meter, it is very thin, I was a bit dissapointed how thin actually but at least I can work it which is what I need to do.
    So does it not depend on the weight of the glass as to how much you get in a roll.
  7. Roly
    Roly Senior Member
    Woven cloth I presuime.
    1000/4.5= 222gm/m2
    222/28.4=7.8oz/m2 which is about 6oz/yd2 which is ok for surfboards or skinning your dingy.
  8. Frosty
    Chopped strand mat,--Is that what 300 means --300 grams per SQ meter or 300 miligrams. It is very thin --ive never seen thinner, you can see through it.
  9. Roly
    Roly Senior Member
    If aint woven or stitched together with threads as in DB,triax,uni, & it looks like csm as in
    random stuck together stands then its csm. I 've never heard 300 for a name.
    And csm comes in oz/sqft. I only ever used it on house roofs.
  1. jrork
  2. pironiero
  3. midcap
  4. tunnels
  6. Jeeps
  7. John Slattery
  8. HG Faulkner
  9. Dan coffin
  10. tevake118
