How is the sheeting arranged for the gennaker on MOD70?
Discussion in 'Multihulls' started by Corley, Jul 8, 2012.
  1. Corley
    Likes: 197, Points: 63, Legacy Rep: 826
    Corley epoxy coated
    I'm just curious whether somebody has a good diagram of how the sheeting is handled for the overlapping gennaker on these boats it looks like a great system and allows for fast tacks, seems to spread the sheet loads effectively and looks to give good adjustability of sail shape. I can see there is a purchase with a block and one line goes to the sail slide another seems to go back to a winch on the coaming. Several lines head to a block above the tramp then seem to mount to the float in two positions.
  2. Gary Baigent
    Likes: 137, Points: 63, Legacy Rep: 509
    Gary Baigent Senior Member
    Looks like a basic (but more complex) barber hauler system with extra lines for clew positioning up and down, in and out.
  3. Corley
    Corley epoxy coated
    Thanks Gary, I found this photo on the Krys Ocean Race site which made it a bit more clear.
  4. Gary Baigent
    Jacques de Reuck has a simplified arrangement on his much modified Piver 24 - which pretty much does the same thing.
  5. powerabout
    powerabout Senior Member
    its just done because the correct sheeting angle is always on the tramp so no hard points to sheet from
