sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
This is a Sen-Dure unit. I can using my fingernail scrape off a layer of slightly sticky stuff from the tubes. This is the coolant side of the unit, not the raw water side.
Looking down the coolant side exit there is this buildup on the tubes, which I scraped off with a fingernail.
Whole thing. I removed it to silver solder the drain plug pencil zinc holder. I then JB welded the ends, and will repaint it. I notice when feeling inside at the cap, it also has a coating of the same stuff, so I think it is all over the inside of it. I may use spray on oven cleaner (lye) to clean it. I know this is made with copper-nickel tubing. All the rest is copper and brass. Mostly copper.
