How About No More Electric Boats?
Discussion in 'Boat Design' started by DogCavalry, Mar 18, 2021.
  1. DogCavalry
    Likes: 700, Points: 113
    DogCavalry I aim to misbehave.
    I appreciate the starry eyed urge to tread lightly, etc. But.
    The environmental impact of Li-ion battery production is very high. Significantly higher than oil production on an energy storage basis.
    The energy that batteries store is almost never made from angel farts. About 90% of energy production world wide is still produced from burning fossil fuels. There are line losses in transmitting electricity. In some regions up to 60%. So the electric boat in those areas burns more fossil fuel than a regular internal combustion engine equipped boat.
    The energy density of a good battery is about 1/40th that of gasoline. Worse for diesel. So the boat has 1/40th the range, or 40 times the weight of fuel in batteries, at massive cost, and significant penalty in energy efficiency because of the weight penalty. And the extra battery weight is made at huge environmental cost. Teslas are 4 door cars. Because they need the frame space.
    Folks get their information about electric vehicles from the marketing departments of companies selling those products. They are about as likely to be telling the truth as a Chevrolet salesman asked by a Ford owner if he should replace his Ford with a Chevrolet. Worse yet are the good and decent folk repeating those lies as if they were fact.
    J
    hoytedow likes this.
  2. pironiero
    Likes: 10, Points: 18
    pironiero Senior Member
    yeah, but its new and shiny, so dumbos want it no matter the cost
  3. rangebowdrie
    Likes: 36, Points: 18, Legacy Rep: 10
    rangebowdrie Junior Member
    You guys are overthinking it.
    The solar panels/batteries provide the power to turn the fans that blow air into the sails,, that way you can keep moving even when the wind isn't blowing.
    hoytedow, BlueBell and DogCavalry like this.
  4. DogCavalry
  5. BlueBell
    Likes: 415, Points: 83
    BlueBell "Whatever..."
    I am really very fond of the panel to motor concept, no batteries.
    Plan accordingly.
    Skyak likes this.
  6. philSweet
    Likes: 240, Points: 63, Legacy Rep: 1082
    philSweet Senior Member
    There's still good old wet lead batteries. They are nearly 100% recyclable. And relevantly, they actually do get recycled. The cost savings with wet lead battery recycling make them very attractive compared to any other type battery.
    Typical grid transmission losses are 5 to 10 percent. Most places that report higher losses have a problem with unmetered consumption (theft); and that's not an efficiency problem. Slow loads like battery charging are good for the grid in general. If you have load management on the charger, it can be very good for the grid. If you have grid tie charging, it is great for the grid. The grid needs more batteries. So realistically, you can have a transmission efficiency effect through load management that is greater than 100%.
    bajansailor likes this.
  7. DogCavalry
    I agree about lead acid batteries, certainly. Efficiency greater than 100% is a system analysis judgement, I'll grant you that as well. Lead acid power density compared to gasoline? Laughable. A very slow displacement boat that uses a massive array of batteries as ballast. Possible.
    Their effect on cargo work done vs carbon output? Questionable.
  8. upchurchmr
    upchurchmr Senior Member
    +1 for checking the actual total impact on enviornment.
    But, all the interest will lead to new ideas in how to iplement electric power.
    So there is still the possibility of better effeciency than combustion based power.
    I just don't have the money to fund the development required.
    Combustion didn't get to as good as it is overnight. :)
    Will Gilmore likes this.
  9. DogCavalry
    Lead acid batteries have about 1/500 the energy density of gasoline by mass. The electric motor is about 5 times as efficient as the ice at converting energy to motion. So my 26' boat will have about 850# of gasoline on board. 45 tons of lead acid batteries is comparably efficient, right?
  10. portacruise
    Likes: 65, Points: 48, Legacy Rep: 218
    portacruise Senior Member
    Lithium is not necessarily a permanent solution, there are cleaner cheaper batteries to be developed, and EV batteries can be configured to sell back power into the grid at a profit during Peak demand, if that's what the owner wants to do. If you like gasoline despite all it's detriments, maybe better to use it or methane in a yet to be perfected Automotive fuel cell in an EV which is probably over 90% efficient and without nitrogen oxides pollution? By comparison, around 80% of combustion in engines is wasted as heat and not used to move a vehicle forward, also has to be drained away from them.
    JMHO.
    Skyak likes this.
  11. srimes
    Likes: 24, Points: 18, Legacy Rep: 214
    srimes Senior Member
    You can't tell me what to do. If I want an electric boat it's my God-given right as an American to buy an electric boat.
  12. clmanges
    Likes: 66, Points: 28, Legacy Rep: 32
    clmanges Senior Member
    Super-capacitors may someday replace chemical batteries ... maybe. Unlike chemical batteries, they have an indefinite lifespan, and they charge in seconds. Assuming they ever get perfected, though, purchase price will be high because they never need replaced, and they might take up a lot of space.
  13. philSweet
    Looking at the propshaft's perspective, you get about 10 hp·h from a gallon of gas and 36 W·h from a kilogram of LAB. That's about 2.75 kg of gas and 206 kg of LAB equivalent. The gas needs a tank and filters and plumbing and pumps and an engine. The LABs need cases and wiring an a charger and a controller and motor. The system weight comparison is highly sensitive to endurance at cruise.
  14. Tiny Turnip
    Likes: 193, Points: 43, Legacy Rep: 743
    Tiny Turnip Senior Member
    philSweet likes this.
  15. rangebowdrie
    At another forum that I was on, a poster wondered why large container ships simply didn't cover the containers with solar panels to provide propulsion,, (use batteries at night).
    They had no idea of the BTUs or KWs necessary to move 100,000 tons, (or more,) at 15 kts,, it's staggering,, not quite like a Prius or a Tesla.
    jehardiman and hoytedow like this.
