honeycomb core edge
Discussion in 'Fiberglass and Composite Boat Building' started by hardcoreducknut, Oct 9, 2012.
  1. hardcoreducknut
    Likes: 1, Points: 0, Legacy Rep: 27
    hardcoreducknut Junior Member
    I'm getting ready to cut out holes for dry storage on my stitch-n-glue that I've built with plascore. I want a nice, even rounded edge. I tested using a router on some scrap and didn't get very good results. Problem is, using a router is difficult because the guide wants to move in-out with the exposed holes in the edge of the core. It's not a straight and solid surface.
    Any ideas/tips/suggestions?
    Thanks!
    Likes: 2,266, Points: 123, Legacy Rep: 2031
    I think your only choice is to glue a ring with the radius you want to the inside of the hole.
  3. iceboater
    Likes: 11, Points: 0, Legacy Rep: 116
    iceboater Junior Member
    I would set up guide for the router on the outside of the hole and first cut the hole with straight router bit with the diameter of
    the bering on rounded edge bit. Then use the rounded edge bit to make the edge using the same guide without moving it.
    Axel
  4. Tungsten
    Tungsten Senior Member
    i would glue in some wood or foam for an edge,dado out a grove to match plascore thickness this will leave a little material proud to keep the water out and your dry boxs dry.
    or go the other way and route a grove in the core and mill a tongue on the wood then you can round over the edge.
  5. Steve W
    Likes: 92, Points: 48, Legacy Rep: 608
    Steve W Senior Member
    Back in 1980 i worked on an IOR maxi race boat build where we used F board aluminum honeycomb panels for all the interior, we routed out the core around the perimeter of every cut edge about 3/8" deep and backfilled it with epoxy/silica.
    Steve.
  6. tunnels
    tunnels Previous Member
    Any of those honey combed cores i have always used foam strips around the edge and cut a chamfer to make the transition . fir it are the same time as you do the core H 80 is easy to cut on a band saw ! and just round the top edge with a block and sand paper the transition is not a 45 degree but should be more like a 30 degree angle !!:)
  7. Canracer
    Canracer Senior Member
    The board manufacturer, should have a guide for this work. With the tools and the strips, epoxy, and all.
    1. Zac Penn
    2. Ctowles
    3. bundaberg42
    4. xiphas
    5. phmadeira
    6. Canracer
    7. Rich Mason
    8. Flyingpumpkin
    9. kenfyoozed
    10. catchcookcreate
