WannabeNavArch
New Member
- Joined
- Sep 2, 2024
- Messages
- Reaction score
- Location
- East Coast
Hi,
I am designing a small family friendly cruising sailboat for a home build. Not sure if I will actually build it but will enjoy the design process. I have a few questions on sourcing components as this will drive a lot of the design. Custom everything seems time and cost prohibitive. Building a mast also scares me a bit.
*Caveat: I am new at this so I am sure I have missed many many critical things.
A little bit about the boat:
Goal: A fast family cruiser. The accommodations don’t need to be fancy since it will be akin to a weekend camper. I would like it to be a planning boat to get more speed.
Note: I really like the Mini 6.5 sailboats but they are too wide to trailer and seem downwind focused. I think a little less beam and a more traditional bow will help upwind?
-Targeting 25ish feet to make it trailerable but can adjust to the rig. I am planning for a mono-hull but see some advantages to a trimaran.
-Beam less than 8’6” as my understanding is that any wider requires a wide load permit in America. Canting the boat on the trailer seems complex but allows more beam.
-Ideally, ramp launchable but flexible on this one.
-Spinnaker on bow sprit as it makes shorthanded sailing easier.
-Seaworthy: I’d like to build it for offshore sailing but this may be prohibitive.
-I am planning to use a hybrid of carbon/s-glass but a plywood hull like the Dudley Dix designs is tempting.
-Any thoughts on adding t foils to the rudders (either on the bottom of the rudder or I-14 style near the waterline)? It seems like there may be some speed and ease of handling benefits.
-The Beneteau First 24 is not a bad match but its expensive and not as much fun as designing your own.
Rig questions: I am engineer and am able to design/fabricate the hull. The sails and mast are items I would like to outsource or buy stock but I a struggling to find options.
-Any ideas on how to economically source mast, boom, and sails? I have struggled to find masts/booms for sale.
-Any ideas on the cost of a semi-custom setup? Maybe it’s not a pricey as I expect.
-Can I stick a Mini 6.5 rig on a slightly larger hull? Any insights on how to source one and what cost might be?
-Ideally, it's carbon mast but aluminum is not a bad option either.
Keel: While I can build a keel, I am little nervous as this is a highly stressed part with safety implications. I lean towards retractable to ease the ramp launching process.
Request help in thinking through the design and sourcing of parts.
Thank you all!
Thank you all!
