ImaginaryNumber
Imaginary Member
- Joined
- May 8, 2009
- Posts
- 436
- Reaction score
- 60
- Location
- USA
Chris,
What is the maximum displacement and lightship displacement of Hogfish Maximus?
How do you expect HFM to behave in a knockdown or a capsize? What is its Angle of Vanishing Stability?
Do I understand correctly that the daggerboard will pop up if it strikes anything? How is the hold-down mechanism constructed?
How is the plywood bottom of HFM built such that it can safely rest on round rocks? I'd prefer not to rest a steel-hulled boat on rocks, to say nothing of a plywood hull!When the tide goes out from under your boat you want a nice soft spot for your boat to sit on for the next 10 hours or so. Sand is great, mud is nice but muddy. Round rocks ok , but move the conchs out of the way if you can. Not for the boat but for them as 16 tons is a lot to bear for the duration of the tide…
You also wrote:
How does your bottom paint survive thousands of groundings? Even on sand it seems that if your boat bumps for 1/2 hour that could be pretty abrasive to paint, and even to epoxy/fiberglass.When the tide goes out we would be on the bottom. No big deal if the wind stays this way. If not when the water comes back we would have about a half an hour of bumping before lift off. This we have done with both Hogfishes at least a thousand times. These boats were designed and built for this.
