Hobbie 18
Discussion in 'Multihulls' started by sailerboy, Dec 6, 2009.
  1. sailerboy
    sailerboy Junior Member
    Hi,
    I am looking at using hobbie 18 hulls as amas (outer floats) on a sailing trimaran.
    Does anybody know the fully immersed buoyancy of a single hobbie 18 hull??
  2. boat fan
    Likes: 17, Points: 18, Legacy Rep: 435
    boat fan Senior Member
    Set the hull on blocks.
    Fill with water.
    Drain into bucket.
    Count the buckets......
  3. catsketcher
    catsketcher Senior Member
    A guess
    You may damage the boat if you fill it with water on land so be careful.
    As a guess the Hobie 18 weighs about 120kg. It can carry two big blokes fine - say another 200kg. And there is still some deck above the water. My guess is around 400 litres.
    Your trimaran idea has been done quite a few times. If you use the rig from the 18 and a surf boat type main hull the boat performs quite well. I sailed on my mates surfboat/Hobie 18 tri and I was impressed with the performance - nice cruising speeds - 7-8 knots in 9 knots of breeze on a reach
    cheers
    Phil
  4. sailerboy
    Thanks for the comments guys.
    Phil, was your mates hobbie surf boat tri a "predator" design or one that he put together himself?
  5. catsketcher
    Just a surf boat
    My friend got a surf boat hull and then fixed it up with some Hobie 18 hulls and rig. It is a great idea. I saw one before that was cruising around the Whitsundays.
    My mate wants to sell it if you want a head start.
    cheers
    Phil
  6. sailerboy
    Thanks for the offer Phil, but not at this stage.
  7. bill broome
    Likes: 2, Points: 0, Legacy Rep: 48
    bill broome Senior Member
    i wonder if using a hull with a transom is such a good idea. it is going to be much more heavily loaded than the cat mode and a deeply immersed transom is not a good feature for speed.
    the h16 is better in this regard, and asymmetric hulls are more useful on a tri than a cat, as well.
  8. sailerboy
    That true Bill, but they don't have enough bouyancy.
  9. aussiebushman
    Likes: 33, Points: 28, Legacy Rep: 132
    aussiebushman Innovator
    Hi Phil
    Probably not ready to buy yet because I have to sell my catamaran (see www.mainproject.info) but I'm interested in your mate's surfboat/Hobie Tri. Please give me contact info so I can get more info and some pictures
    Cheers
    Alan
  10. catsketcher
    Hobie 16 or 18
    The only people who can really say whether the Hobie 16 or 18 would be best would have sailed with both. Dick Newick did design a great boat called a Tremilino which was a dory hull with Hobie 16 floats. If Newick thought it was good then it can't be bad. I saw one in the early 90s in Pittwater. The guy used to have a mould but as the boat was flat panel it would be better top build it out of ply or foam.
    In the end Newick designed bigger floats for the tremilino. I have sailed the surf boat with the 18 floats and would definitely go this way. It is true that the float sterns are larger but this may not be such a bad thing. The floats themselves are much more buoyant and I didn't find the immersion of the floats transoms to cause much drag. The idea of the pin ended float was a big thing in the 70s and 80s. Floats now seem to carry their volume much further aft on most modern tris. The decks are also much higher which will reduce drag greatly compared to if you put the crossbeams straight onto the 16s deck.
  11. aussiebushman
    Phil
    Are you going to be in Sydney on the week of December 21? If so, I'd like to get your comments on a proposed hybrid with Hobie 18 amas and a completely new main hull based on the Catri 24. Using published info on the latter, (I asked permission to do so), I have lofted the lines and produced a table of offsets, also a 1:20 balsa model. I think this will be a knockout as a cruising Tri and later, I'll share this development with others on the forum, but a bit of local comment from someone with your experience would be very helpful. You can call me on 0418 230562
    Cheers
    Alan
  12. bill broome
  13. aussiebushman
    Hi Bill
    Thanks for that - though the link is broken, I think I have already looked at most of the Tremolino material as well as the Dix threefold-six and Kismet 23/24 options. Another contender might be the Trinardo - lovely design that will work with Hobie 8 Amas and this may yet be the selected option.
    However, what I like about the Catri 24 is the superb hull shape - beautiful entry lines, a knuckle hull where the wetted area is low but the interior space is huge, relative to overall length and for a cruising boat, that matters to me. The speed is of far less consequence as I shall never race it. 6 Oz glass/epoxy over 9mm WRC will not be as light as the foam original, but stronger and again, as a cruiser, that matters.
    The scale balsa model is nearing completion - used to "prove" the offset table I developed.
    The offer to catch up with anyone in Sydney on Christmas week stands - maybe on the catamaran in the Lane Cove river for a beer?
    Cheers
    Alan
  14. sysfx
    sysfx Junior Member
    If you plan to have a folding system, try to place the struts higher than the chine to avoid excessive spray. Streamlining the struts is not enough to reduce the spray.
    Good luck,
    Luiz S
  15. aussiebushman
    Hobie 18/Catri-style composite
    Thanks Luiz, I agree. They will not be "constant camber", but they will be set high enough to avoid impact except in extreme cases.
    For interest, I'm attaching some pictures of the scale model. You will see the beams are set into the sheer, well above the chine, where they provide maximum lateral strength too, while not interfering with the internal layout. The beams will fold upwards - not shown in the pictures, but they allow the amas to vitually touch in the centre above the main hull
    Comments from all welcome
    Cheers
    Alan
