high speed boat design
Discussion in 'Boat Design' started by srinath88, Feb 26, 2015.
  1. srinath88
    srinath88 Junior Member
    hi i want to know good range of VCG for 1.5 to 2.5 m(LOA) boat. Boat will carry 100 to 250 kg it is planing type boat.
    and please tell me idea(accuracy) of below software to use 1.5 to 2.5 m (LOA) boat
  2. daiquiri
    Interesting SOR. What kind of boat is it?
  3. Alik
    Likes: 384, Points: 93, Legacy Rep: 1306
    Alik Senior Member
    Something like this? This one is in FRP. Photo taken in SriLanka...
  4. srinath88
    it may be Autonomous vehicle or Unmanned vehicle
  5. srinath88
  6. daiquiri
    Since I can't see what would be a civil use of an autonomous high-speed vessel of that size, I guess it is intended for military use?
  7. Alik
    Alik Senior Member
    Smuggling. It is civil use as well :D
  8. srinath88
    this design is not for military purposes. it is for university project :mad:
  9. Alik
    Alik Senior Member
    srinath88, to be serious, there is 'no good range of VCG' (vertical center of gravity). VCG should be such to provide adequate stability. Stability is characterized by set of criteria, there is no just one criteria making VCG good or bad.
    For USV boat of considered size, I would assume the boat should be self-righting. So the design flow is: sketch the GA, sketch the geometry in 3D including above-deck volumes, prepare preliminary table of weights with displacements and CG position, calculate the stability. Adjust above deck volume for self-righting, adjust table of weights and repeat the process again.
    We used pole with buoyancy on self-righting radio-controlled model, maybe this will help.
      File size:
      1 MB
  10. srinath88
    thank you for answer what about "Planing new.xls" accuracy for 1.5 to 2.5
