Doug Lord
Flight Ready
- Joined
- May 26, 2009
- Posts
- 16,679
- Reaction score
- 354
- Location
- Cocoa, Florida
Fire Arrow Foiler / MPX Foil System Testing and Development
More on the new surface piercing main foil(with downforce) : I'm thinking that it could have an application on a racing version of the Fire Arrow even w/o intrinsic downforce because it would drastically reduce the wetted surface of the main foil. And on a racing version, if downforce was wanted you could include a flap on the center section that you would simply "shift" to begin downforce.
More on the automatic main foil: I'm designing the model version now and the way to set it up follows, based on the last sketch of the last post:
1) the sections of the foil outboard of the fences will twist(washin) from a nominal AOI(angle of incidence) of 2.5 degrees to an AOI close to the tip of +6 degrees,
2) the center section consisting of an inverted asymmetrical section will be set up with the nose up 2.5 degrees.
3) this is based on an expected(will be measured exactly in our next tests) 2.5 degree pitch down at speed, which will:
a.cause the inboard half(the immersed portion) of the outboardsections to have an an angle of attack of zero degrees, and,
b. cause the nose of the asymmetrical center section to operate at an AOA of zero degrees, which, if a similar foil to a 63412 is used, cause downforce to be developed with a section lift coefficient of about .3.
The viability of this concept depends on, among other things, knowing the exact pitchdown of the boat at speed. This is where the damn no good go pro would come in handy or one of the cheaper versions-- to be able to watch the wand lever to tell exactly when the foil begins to develop downforce. It's probably not possible to see the wand with sufficient accuracy to tell that this has just started.
click---
Thanks, Paul. The main foil, with dual wand controlled flap, is unquestionably the best for performance. But since this is a scale model of a "sport" boat and not a scale model of a race boat, I've been trying to see if I could come up with a surface piercing main foil that could somehow be designed to produce downforce before the main foil flys due to heeling force- to further simplify the foil system.
Right after takeoff, whether the main foil is a surface piercing foil or fully submerged wand controlled foil, it begins to unload with more and more of the load taken by the ama foil. That's all automatic. And the characteristic of the boat as it speeds up is to pitch down. My use of the asymmetric center section is to take advantage of the fact that an upside down asymmetrical foil will generate vertical lift(an airplane with an asy wing can fly upside down) with the right angle of attack and that while upside down it will generate downforce with a low positive angle of attack or zero positive AOA, while the inboard sections* of the symmetrical foil are at zero degrees angle of attack producing no vertical lift-all this when the boat is at max pitch down.
Whats hard in studying this is to remember that the heeling force is increasing as the boat speeds up and pitches down. And that the heeling force unloads the main foil.
At max pitch down there is a symmetrical foil and asymmetrical foil cruising along right next to each other ,separated by fences. The symmetrical foil is at zero degrees AOA and so is the inverted asymmetrical foil. Because an asymmetrical foil can generate vertical lift at zero degrees AOA, it can generate downforce when inverted at the same angle of attack!
So I guess I think it's ,at least, worth a test.....
*which are the only portions of the symmetrical foils that are immersed at that point.
